Re: Arch LS
It will flicker when the battery is about to run out and the light is falling out of regulation. Usually, a battery lasts about 2 hours.
You should probably check your light with a fresh battery. If it still flickers, the switch is probably defective. If it doesn't, you should be all set.
Good luck,
Pat
