Are There Any Other Bulbs for the Rayovac SP8D Sportsman Area Lantern Besides Stock?
LEDAdd1ct
Hudson Valley
When I purchase a product, I like two things:
1) Replacement parts should be cheap
2) Replacement parts should be widely available from multiple sources
The Rayovac Sportsman SP8D Area Lantern uses two 9 watt tubes. However, I can only find Rayovac selling replacements. According to this product page here, the bulbs are 60 volt, 150mA, and have four pins. Though I can find multiple hits on google for 9 watt tubes with four pins, I cannot locate any designed to work off 60 volts. Is it really possible that only Rayovac/Spectrum Brands sells a replacement tube? I find it hard to believe.
Though I do not own one, the rubbery bottom and handle, even brightness, and lifetime warranty all appeal to me. Judging from the Sportsman Extreme and Gentos models, the Rayovac/Spectrum branded Favourlight stuff is of much higher quality than the fragile Coleman junk. However, I would feel much better if I knew there were other companies making four pin, 9 watt, 60 volt tubes.
*scratches head*
NOTE:
This is the lantern being discussed
And for the answer:
I found what appears to be an excellent third party replacement. Go for the Sylvania, model #20313. Here are the specs:
Base: 2G7
Pins: 4
Watts: 9
Volts: 48
Amps: 170mA
Initial Lumens: 580
Mean Lumens: 522
Color Temp: 2700k
CRI: 82
Average Rated Life: 10,000 hours
Source (links to a Google Quickview of the Sylvania PDF)
Source (links to the PDF itself)
NOTE: Although this tube by Sylvania appears to be compatible, I suppose we won't know for sure until:
1) Someone compares the two physically
2) Someone installs it and finds out
Any takers?
Here is another one that looks awesome:
Osram Dulux S/E 9W/827
Brand: OSRAM
Part Number: 017655
Weight: 100 grams
Colour: Warm white
Voltage: 48 volts
Specific Uses: Indoor use only
Type of Bulb: CFL
Cap Type: 2G7
EU Energy Efficiency Label: A
Luminous Flux: 600 lumen
Wattage: 9 watts
Incandescent Equivalent: 40 watts
Colour Temperature: 2700 Kelvin
Average Life: 10000 hours
Bulb Diameter: 34 millimetres
Bulb Length: 150 millimetres
Source
Both Sylvania and Osram have variants at higher color temperatures. But a lot of people like their lanterns nice and cozy!
Mmmm...2700k lantern lighting...
