Klaus,
I'm not disputing the specifications as you have listed.
The AA or AS does not specify the HDT (Heat Distortion Point??) as other technical publications for other epoxies are listed.
It's just a point of reference where the epoxy starts to soften or HDT, not where the epoxy fails.
100F or where the epoxy gets soft in no way means it is beyond it's useable range.
I'm only pointing out that some epoxies have a lower HDT point and that the higher the HDT, the better mechanical strength the module will be. Using a low HDT epoxy may result in the module crushing over time due to heat.
I'd hate to see anyone go through all the trouble of building a sandwich and have it collapse some days/weeks/mo's later.
There is no real reason to use AA in the Sandwich module. Cost per oz of epoxy, AA is very expensive. A two tube Devcon 2ton or others you can find at the HW store cost similar to AA but can fill 3-10 modules. That and the fact the epoxy is there more for mechanical strength and not thermal characteristics.
In fact, I think Bondo is good epoxy for temperature. I used to use this a lot when I built model airplanes and if I recall, Bondo didn't show any signs of HDT at all. Maybe, that is because of the filler being used. If you can goop some bondo as the filler it should be fine too.
When it comes to mixing epoxies the ratio is very important to the outcome of the properties of the cured epoxy.
Even 2ton won't cure if the ratio deviates too much.
Epoxies especially when mixed in small quantities are much harder to control the ratio of partA to partB. This resultant effect could weaken or change the HDT point dramatically.
I use a pump base system that dispense a precise partA partB and a combined resultant of 1oz worth of epoxy. The pump system is very accurate and the resultant epoxy cured will be similar from batch to batch. Even then, I post cure all my modules to try to raise the HDT as high as possible. The 1 oz BTW will fill approximately 30 modules and that's the quantity of my builds. I have tailored my module assemblies around this amount of epoxy as a single run to maximize the process.
Wayne
[edited]
Found a glossary term on the web:
Heat Distortion Point The temperature at which a test bar deflects under a given flexural load and a prescribed amount of heat.
http://www.matweb.com/reference/deflection-temperature.asp
