mehansen50
- Joined
- Mar 28, 2008
- Messages
- 1
Does anyone know the details of these light or where I can something similar to a custom car I am building? Thanks Mark
PIAA has an LED DRL option: http://www.shopatron.com/product/part_number=19152/353.0
The normal Audi R8 doesn't have 'driving lights' certainly not in the traditional sense of the term.
It has bi-projectors with an HID light source, and has LEDs to perform a DRL function.
Unfortunately it is of a way too high white point, 6000K.
Or if you want real lamps built to a recognized technical standard instead of overpriced lamp-shaped toys built to the thoroughly un-technical whims of PIAA's marketing staff, Hella has a range of LED DRLs. Round, rectangular, strip-shaped...some of them have control circuitry to let them do both the bright DRL and the dim position (parking) lamp function; see http://www.tagfahrlicht.com .
I'm not sure about the LEDs used in the Audi, but I might be able to make suggestions about something similar.
What output?(at least 1500 lumen is my guess)
Beampattern?(I'd presume wide oval shaped hotspot)
Power?(probably 12v)
:welcome:
The Audi's headlamps will have to comply with both US standards and European ones. Euro standards call for a very sharp cut-off, horizontal to the left of center and inclined up from center to periphery at about 15 degrees on the right. This is true regardless of whether they are tungsten-halogen, HID or LED. I don't know which, but most likely HID or LED.
I don't remember which FMVSS (Federal Moror Vehicle Safety Standard) covers headlamp beam patterns but you should be able to find out from NHTSA (National Highway Traffic Safety Administration).
