reviewum
Hey All,
It's been a while (years) since I've called on the collective genius of the members of this great forum, but I need some help.
I have 7 chickens that put themselves into the coop at night, but the dummies won't close / lock the door behind them (go figure). If the wife and I don't get home in time or forget to close the coop door then we've left a tasty snack for local raccoons.
So, I want to build a contraption that will close the coop door automatically at night. I know there are plethora of ways to accomplish this (photo resitors, geared motors, etc.) but I want to keep this as simple / fool proof as possible.
Here is my idea / design so far:
1. A vertical door (on rails?) that is lifted and latched manually (using a pin).
2. A simple timer (the $5.00 guys you get to turn lights on and off in the house) that is set to turn on at 7:00 pm and run for the smallest interval of time (say 3 minutes).
3. A solenoid, actuator, etc. that will be activated when the timer kicks on and pull the pin.
4. The door is released and gravity pulls it down to closed position.
So, where do I need help? Well, everything related to step 3, especially related to whether I use a solenoid or an actuator? I need something that:
1. Can run off a simple wall adaptor (Around 12 volts and 300 mA?)
2. Is strong enough to pull a pin under a little bit of load
3. Can be on for 3-5 minutes without burning up
So, any suggestions, pointers, advice to save our chickens?
Thanks in advance for your help.
