AW RCR123 Battery ????
Brian321
St. Peters, MO
Ok so i recently bought some AW RCR123 batteries and i was testing them with my surefire flashlight (with Malkoff M61) to see how long they would last on a full charge. Well they only lasted 1 hour and 5 minutes then just completely shut off,(they didnt dim or anything) :faint:. The M61 is suppose to run for 2 hours on two cr123's. You guys have any thought on this??? Thanks.
Of course they completely shut off, they are PROTECTED Lithium-Ion cells. 16340-sized li-ion cells have about 500 to 550mAh real capacity, disposable CR123 cells have 1300 to 1500mAh, depending on brand/quality. So what did you expect?
+1 to what Outdoors Fanatic said. It's normal for that type of battery to totally shut off, and the run time on rcr123 is going to be much less because it has a way lower capacity (mAh) than lithium primary cr123 cells. Totally expected behavior.
You will get far more runtime with one 17670 (or even better yet, an 18650) compared to 2x RCR123 (for the same length) in the same host. Output should be the same, but we need to get tailcap current figures for both configurations to make sure.
1x 17670: ~50% more runtime compared to 2x RCR123
1x 18650: ~150% more runtime compared to 2x RCR123
That's why a lot of folks here are getting their SF's bored for 18mm cells.
How was the brightness with the AW RCR123 and the M61? Was thinking about giving this a try too.
In the brief time I had a M61 I tried 2x AW R123's, 2x Battery Station CR123 Primaries, and an AW 18650 2600mah; I couldn't tell a difference in brightness between any of them.
Others have posted otherwise, but I don't see how the brightness could vary between them when it's a regulated light (unless you go below the 3.4v minimum current then it goes into direct drive).
Also do keep in mind that all RCR123 batteries have a lower total capacity than primary CR123 cells. Just the nature of the beast.
What calculation do you use to arrive at those results? They seem to be exaggerated to me.
2xRCR123
3.6v*2*750mAh = 5400mA-volt-hours
1x17670
3.6v*1600mAh = 5760mA-volt-hours
1x18650
3.6v*2600mAh = 9360mA-volt-hours
By these calculations, 1x17670 would give you a 7% increase in stored energy over 2xRCR123, and 18650 would give you a 73% increase in stored energy over 2xRCR123.
Using actual capacity figures, not claimed capacities.
For example, with a one amp draw, an AW RCR123 delivers something like 500 mAh IIRC (need to look at data from SilverFox), not the claimed ~750 or whatever. The larger AW cells deliver much closer to their claimed capacities. (~1600 mAh from the AW 17670 & ~2600 mAh from the AW 18650 LiIon)
Edit: here we go with SilverFox's test thread:
http://www.candlepowerforums.com/vb/showthread.php?t=117117
  • AW RCR123, 1 amp drain rate: 420 mAh, 1.4 Watt-hours
  • AW 17500 (for example, not coming across test data for the other AW's at the moment), 2 amp drain rate: 1090 mAh, 3.8 watt-hours
So since the 1100 mAh AW 17500 tests very close to the claimed rate, I'm going to assume the (larger yet) 17670 & 18650 does as well - this assumption has been generally supported by a fair bit of CPF postings IIRC. Perhaps Mdocod or Silverfox may chime in with more specific info.
So, suppose we were going to draw 7.4 watts (for example) from a 2x CR123-type flashlight:
2x RCR123: 7.4 W / (2x3.7) V = 1 amp from the 2x RCR123 stack. For this situation, 2x RCR123 will deliver 2x1.4 = ~2.8 total watt-hours
1x 17500: 7.4 W / (1x3.7) V = 2 amps from the 17500. For this situation, 1x 17500 will deliver 1x3.8 = ~3.8 total watt-hours
Therefore, from the test data for AW cells, it can be concluded that 1x 17500 contains 3.8 / (1.4x2) = 36% more stored energy (i.e. watt-hours) than 2x RCR123 for the same total wattage condition. Taking this example from 1x 17500 to 1x 17670 and further yet to 1x 18650 gives addition impressive gains in capacity.
Thanks for the explanation. That makes sense. :thumbsup:
NS, I've edited my post above using AW test data by SilverFox.
(It's even more dramatic than I remembered, the AW RCR123 was tested to deliver only ~420 mAh at a one amp drain rate. The larger AW cells just crush this little guy for actual mAh).
I'm really really happy that we are getting LED modules that perform better and better in a relatively low-voltage configuration (i.e. from single 3.7v LiIon cells) - the sooner we can get away from 2x RCR123, the better off we'll be:
Single large LiIon cells (like 1x 17670 or 1x 18650):
  • substantially more usable capacity than 2x RCR123 (for the same length)
  • more reliable than 2x RCR123 - fewer components to fail
  • safer than 2x RCR123 - no chance of cell imbalance / reverse charging
  • comparable cost (or even slightly less expensive) to 2x RCR123
  • easier cell changes - one cell goes out, one goes in. Handling 2 depleted cells and two fresh cells (in the dark perhaps?) gives much greater chance of mixing them up.
@ Kestrel - the thread you linked by Silverfox tests the old AW RCR123's - the new AW RCR123's are much better.
Thank you very much for this info, I would find that very interesting. If you could you direct me to newer test data, I would be happy to re-run my calculations above - I love this kind of stuff. :)
Thanks much,
K
(BTW I've requested this thread be moved to the \Batteries subforum)
I just came across some decent data for the AW 2600mAh 18650 from late 2009:
http://www.candlepowerforums.com/vb/showthread.php?t=257543
2500 mAh @ 0.3 amps
2480 mAh @ 1.0 amps
2400 mAh @ 3.0 amps
So at the drain rate I tried to model earlier in post # 9 (2.0 amps), we're talking about ~2440 mAh. Not too shabby.
When I come across better (i.e more recent) data for the AW RCR123, I can recalculate this comparison using this mAh figure for an 18650.
Just to add a little note of observation.
The AW RCR123's for me peak from a 2.998v state to 4.2v at around 550mAh, obtained using a Multiplex LN-5014 and custom balancer setup on an Electrifly Equinox balancer.
I was a little bit disappointed in the false advertising with the AW cells compared to what I'm used to in the RC world of lithium polymer batteries which are true to their word.
Afaik, it's not so much AW, but the 16340/RCR123 format, which has always been overrated, regardless of the brand. I've seen many 900mAh (or even higher? I can't remember) cells which are obviously the case.
However, I do think that the AW cells should be performing better than that. How old are yours? The older production cells already reached 600mAh at 0.5A, and the new ones should be even better.
I have also tested some AW 16340 on my CBA and it was around 550 mAh
OK, so here's my attempt at the most definitive answer possible for a regulated LED module which runs at or near spec from 3.7v up to 7.4v:
Reading the most recent posts for the actual tested capacities of the AW protected RCR123's, I'm going to go with 550 mAh @ 1 amp drain rate (data posted above by RTTR and HKJ, and which is probably comparable to 600 mAh @ 0.5 amp drain rate which was also posted above).
For the AW protected 17670's, I'm going to go with 0.99 x 1600 = 1584 mAh @ 2 amp drain rate, since the similarly-sized 17500's tested at 99% of their claimed 1100 mAh for that drain rate, from SilverFox's data cited in my earlier post (#9) in this thread.
For the AW protected 18650's (2600 mAh), I'm going to go with 2440 mAh @ 2 amp drain rate, from my interpolation of data cited in my earlier post (#14) in this thread.
So, again using a hypothetical wattage drain of 7.4 watts as in my Post # 9 (This was chosen for ease of amperage drain calculations - remember, we often only have capacity data for specific drain rates such as 1 or 2 amps, for example).
So for this example, we are drawing one amp from 2xRCR123 vs. drawing two amps in 1x17670 & 1x18650 to maintain the same wattage throughout our comparions:
  • AW RCR123's: (0.550Ah) x (3.7v) x (2 cells) = 4.07 watt-hours of total energy capacity
  • AW 17670's: (1.584Ah) x (3.7v) x (1 cell) = 5.86 watt-hours, a gain of ~45% for a configuration of the same length.
  • AW 18650's: (2.440Ah) x (3.7v) x (1 cell) = 9.03 watt-hours, a gain of ~120% for a configuration of the same length.
I have tried my best using data and information posted on CPF to come to a definitive comparison of the three common AW LiIon configurations for a regulated LED module which can operate at or at least near spec from 3.7v up to 7.4v. The only oversight (besides possible internal improvements to subsequent generations of LiIon cells) that I can see at the moment are slight differences in voltage drops under load - this will give the 18650 a slightly greater performance edge, as the calculated watt-hours will be slightly higher than the above (perhaps ~3.8v vs ~3.7v from the smaller LiIon cells of considerably less capacity :shrug:).
Edit: As an aside, let's see how many watt-hours we might get from 2x SureFire CR123 lithium primaries for the same wattage draw, as the OP for this thread was hoping to make that comparison:
7.4 watts / (~2.5 volts under load x 2 cells) = 1.48 amps, let's call that 1.5 amps.
Using this data from Silverfox and interpolating the total delivered watt-hours between the 1 amp and 2 amp drain rates:
3.123 watt-hours @ 1 amp, 2.073 watt-hours @ 2 amps, interpolated to 2.60 watt-hours @ 1.5 amps.
2.60 w-h x 2xCR123 = 5.2 watt - hours for 2xCR123.
Therefore, the only way to match the capacity of 2xCR123 lithium primaries in the same length host is to use 1x17670. In addition, the capacity of 1x18650 beats 2x CR123 lithium primaries by ~75% in a host of the same length, a very impressive achievement for rechargeable cells. :thumbsup:
I understand that this is for a relatively high drain condition (7.4 watts), as the Malkoff M60 generally operates at ~4.5 watts, but remember, we generally get LiIon mAh data posted for 1A & 2A drain rates in CPF, and I chose this 7.4 watts as a result of that, to facilitate comparisons between 1x LiIon and 2x LiIon. Things should be reasonably comparable for lower wattage conditions, as the above situations should still be proportional. I suppose I could re-run all this for a 7.4W / 2 = 3.6 watts condition (probably pretty close to the wattage of the OP's Malkoff M61), as we can come up with RCR123 capacities @ 0.5 amps & 18650 capacities @ 1.0 amp, but it should pretty much demonstrate the same thing.
And as 'Forrest Gump' said:
"And that's all I have to say about that."
