ionizedsky
- Joined
- Dec 30, 2008
- Messages
- 226
So I recently purchased the ITP A3 EOS upgrade model, I really like this little light a lot. It is very bright on high and the multi-mode switch (twisting the head on and off to cycle modes is easy). Well recently it took a washer/dryer cycle and doesn't seem to have made it (trying a few resurrection ideas).
Which brings me to second little light that is really impressive. I recently made a trade and the person I made a trade with was really generous and threw a freebie in he wasn't using, Streamlight Microstream. I like this little light tremendously for a lot of reasons.
1. Clicky tailcap that is rather sturdy from the way it feels.
2. It has a fairly deep bezel down clip on it that makes it a nice fit for a shirt pocket with flap cover carry.
3. It has a really nice finish on it that is very durable, as the clip rubs the battery tube when your taking it apart to change the AAA and it does not scratch the finish.
With all that said I also have recently purchased a Quark Tactical 123^2 and the trade mentioned earlier was for Jetbeam Pro III ST BVC R2 which share a fairly similar UI. The difference that I like about the Jetbeam is it has absolutely no preflash when switching off in high mode and then while still off twisting the head to low and then turning on.
So with all the anticipation aside, I propose this back up light idea.
-The light would be something very similar in design to the streamlight microstream (obviously some changes will be made to not infringe on trademarking issues).
-Taking the Microstream into thought, the head would be changed to a threaded head for UI but would have a dual o-ring design at the all threads and potential leak points.
-UI would be like the Quark Tactical and Jetbeam I.B.S. or other similar lights not mentioned. The difference would be as this is strictly for back up it would only have a high (80lumens minimum) and Low (10lumens) which would be controlled by tightening and loosening the head just a little and turning on by clicky tailcap. Now there would have to be absolutely no pre-flash like the Jetbeam for obvious reasons.
-It would have to be about the weight of the Microstream (1.04oz with battery-Streamlights specs) no more than 3oz
What is every bodies thoughts, opinions, criticisms, whatever lets here it.:poke: = :duck:
