moraino
I am thinking of using Badboy for my new mod, the ASP with LS 3watt powered by 18650 Lithium. I want high ppower with flat curv.
The maximum voltage will be 4.2 volt. I am wondering if it is ok to run the Badboy at that voltage. It seems somewhere I read that the input voltage should not be higher than the LS Vf.
I know of a 1W stepup converter will run direct drive if the input voltage is higher than the Vf. Does Badboy operates the same way? If not which converter should I choose. Thanks for the inputs.
Henry
Ooops, I post this at the wrong group. Please move me to the Sandwich Shop. Sorry for the trouble.
Henry
