Hi Folks
So I'm pretty sure I'm going to purchase an RA Clicky Tactical 170 and I'm considering running it on rechargeable Li-Ions. I've been doing a lot of reading on the rechargeables and there certainly is a lot to learn. So here are my questions:
1. Will I get greater run time, less run time or about the same using a single rechargeable 123 as a primary cell?
2. I know the AW rechargeables are highly regarded...at least I think they are by what I've read. I also noticed that the AW rechargeables are rated at 750mAh. Then I noticed that HDS sells Battery Station rechargeables and that these are rated at 900mAh. I've read so much in the last few days that my brain is on overload. I thought, however, that I came across a comparison thread and the Battery Station rechargeables faired better than the AW's for run time...which I assume makes sense since they are 900mAh. Or am I wrong about this? My real question is, which is going to be the best rechargeable for this light? I was also thinking that it might be significant that HDS chose Battery Station and that this is probably at least a solid choice if not the best choice
3. I've noticed that the RCR123's are rated at either 3.6V or 3.7V. How significant is this (guess I have a bit more to read on this)?
4. Any comments about my choice in running rechargeables, my choice in the RA Clicky, etc., are apprciated. I'm looking at the Pila IBC btw for the charger...at least I think I confirmed that it can charge the 123's using spacers.
Thanks for the help...and patience with a newbie!
Peace
Peace
