crislight01 Newly Enlightened Joined Apr 12, 2007 Messages 172 Jul 16, 2007 #1 hi is there a way to manually discharge batteries ? thanks
coppertrail Enlightened Joined May 21, 2006 Messages 920 Jul 16, 2007 #2 One way is to use a charger that has a refresh or conditioning mode. You could also use the device to drain the cells down (until the device shuts off) then charge them back up again. I prefer the former method.
legtu Enlightened Joined May 19, 2004 Messages 516 Location PH Jul 17, 2007 #3 a resistor with the proper value and rating can also be used. you'll have to monitor battery voltage though is it can severly disharge a batt.
