Hi,
I've just bought an Olight M20 R2 (well it’s in the mail) and I plan to back that up with fenix tk11 soon and also a P1D Q5.
I plan to use mostly AW's rechargeable 18650's and CRC123A's.
My question is what is the golden rule (if one exists) for the above batteries to power the above lights?
I've seen bits and pieces on the net of where its acceptable to use 3.7v batts in 6v lights and but not in Incans, only LEDS? Or vice versa etc etc.
Then there's protected and not protected cells...... what’s better.
The other thing I need to consider is I’ll still be keeping my current G2 setup (p61 lamp and a lite saver multifunction tail cap) so I want to get batteries that will not effect that set up's Incan performance.
And then 4sevens has a AW's R17670 which seems to be just a single cell @1600mah that replaces 2 RCR123A's @ 1500mah. What’s the deal there?
+ what’s the best dual bay charger that can charge 18650's and 123A's? 4sevens seems to be offering a 'Ultrafire' dual bay charger.
Also in the future, i plan to purchase a Z2 and drop in a Malkoff M60 (haven't decided whether i'll just go for the M60 and sacrifice the runtime for huge output and throw and or if i'll be slightly conservative and go for the M60L) so i'll need to look at 123a's for that setup.
So in short, I’m being slightly lazy and naieve and wanting a crash course in batteries from you guys rather than me trawling the net for research or reviving my high school physics.
Can you help?
Cheers!
Can you help?
Cheers!
