I have a pair of Motorola walkabout T5500 radios and the battery packs in them have gone bad. I took one of the packs and tore off the plastic wrapper. It appears to be 3 AA in series that have 600mah rating @ 1.2 volts each. You can also use regular alkaline AA's and it works fine. I figured I could buy 6 new rechargable cells, reassemble the packs, and use a smart charger for them. One of the "charging strips" on the packs also has a resistor going to the "+" terminal. I'm assuming its to reduce the charging voltage from 9v as the transformer output is 9V @ 200ma. There is also another "chip" in the pack, but I don't know what it is. I'll try and take a pic when I get home. Sound like something that can be done? My overall idea is to upgrade the packs for longer life(runtime as well as battery pack life) and use the original charging base minus transformer with a different charger... What do yall think??
Edit: here are the existing packs....
