Base on the cost of the batteries alone, the weight of everything, and the rechargablility of it, I think, if you are building this for fun, unless you have time and money, it's not worth it.
If you are building this for use, the above mentioned reasons would make it not so feasible either. I would propose you go with a 150 watt - 200 watt HID light. They are white, much more efficient and almost as bright as a 600 watt incandescent lamp. Not to mention you can focus them really tight. If you go this route, batteries would be reduced by 1/3 or that run time could be increase by a factor of 3-4 times. SLA batteries, 12 volts type (fully charged, will be 14-15 volts?), 20 AH, would weight like 30 pounds? (not sure), and give you a 1 hour run time on a 200 watt HID light. Charging could be done overnight. Battery would be the length of 3/4 of your keyboard, 1/3 the height of a 17 inch monitor, prolly 1/3 of your keyboard in width? (not too sure either)
A light like this would put out well over 10K lumens @ minumum. /ubbthreads/images/graemlins/bowdown.gif
Even without the visible light, using a infra red filter, you could probably barbeque food with the projected infra red from the HID! /ubbthreads/images/graemlins/icon15.gif
