Battery Protection Circuit IC help
kingofkeys79
I am designing a PCB (Protection Circuit Board) for a single cell Li-ion battery.
I know I can buy these PCBs, but I have a limited space to work with and since I have worked with printed circuit boards and ICs before I assumed this task would be trivial. Here is what I have so far:
IC for over voltage, under voltage and over current protection of single cell Li-Ion:
http://datasheet.sii-ic.com/en/battery_protection/S8241_E.pdf
I understand how everything works, except one thing: how does the over current protection work? In other words, how do I set my current limit to 500mA or 1A, or 2A. I was looking for some cap and resistor values to control the current limit value, but that doesn't seem to be the case here. I read through the entire datasheet a few times but I cant seem to figure it out!
Someone please help me!
The on resistance of the power fets controls the current limit. Remember that this resistance is temperature depend!
Ooo! That makes total sense. So the ideal current limit = (voltage listed on the IC datasheet)/(on-resistance of the two mosfets) :)
Thank you HKJ
I have a follow up question that is confusing me a little.
So if I want a current limit of 0.5A, then according to the equation above (with voltage listed on the IC = 0.1V), then the on-resistance of the two mosfet has to be 180 milliOhms. Would not building such a design give me a lot of power loss? What are my options?
It will give some power loss, but not that much, remember that it is 0.1 volt from 3.6 volt.
I believe that this voltage drop is the reason some manufacturers uses limits of 10-12A on the LiIon batteries, instead of the more reasonable 6-8A
You can get chips with lower voltage threshold.
Remember that resistance does also include loss in mosfet connections and PCB traces, you can even add a resistor, to get the lower limit.
In that case, if you look on page 27 of the datasheet, it shows a resistor R2 = 1kOhm. Should I add this into my calculation of the current limit. ahhhhh I am loosing my basic circuit analysis skills
Edit: If I do include the R2 into my calculations, then the equation becomes Current Limit = VM/ (R2 + on-resistance)... and that equation doesnt make sense because R2 is HUGE! What am I missing here?
*VM = Voltage threshold for over current detection listed in the IC datasheet (0.08V)
No, it is for reverse charge protection.
A resistor would have to be added between FET2 and the junction with R2.
