Battery Spacers - what do they do??
Jonster
Gloucestershire, UK
I've seen some magnetic battery spacers on DX ... are they literally just to space out batteries which don't have the +ve "nipple" on the end? or do they perform other functions?
Also does anyone know if magnetic battery spacers should be put on a specific way round?
If you put them the wrong way round would it drain the battery / get hot?
They're used to facilitate the connection between two "flat top" batteries as you mentioned. Also used to allow a flat top battery to contact the positive contact in a flashlight that doesn't have a spring for the positive contact. Doesn't matter which way you attach the magnet. :)
Many people don't recommend using them (me included) because they can shift and contact the flashlight housing. If the housing isn't anodized, the battery can short out... not good. :) If using protected batteries, the battery's protection will kick in during this situation, preventing the battery from shorting. But, protection circuits have been know to fail... I wouldn't want to rely on it. If using magnets with unprotected batteries, well.. you're just asking for trouble. :poof: At least try to find magnets that have the sides encased with insulating plastic. :thumbsup:
Cheers FlashCrazy,
Makes sense ...
I'm just sat here wondering - how well would they hold the batteries together if you knock your torch (or bike light) about?
I'm picturing my local drop-off ... weeee ... !!thump!! ... batteries lose contact and the light resets to low power ... aaargh ... I can't seee .... second thump as I hit a tree ... nee-nah-nee-nah!!! :twothumbs
oh no, it won't reset to low power.. if the magnet gets knocked loose, then the battery will probably short, with would either:
1. if using a protected liion, shut off the light until the circuit is reset.
2. turn your light into a hand grenade if there is no protection circuit.
I presume you're referring to what would happen to a dislodged battery in a metal housing.
In my instance I'm going to be using a plastic tubular housing but in any case if the picture on DX is correct the 18650's heading my way won't need any spacers.
Cheers bud
Britney Spears? Sings, dances, among other things...
well, the + and - contact points both have to be in the head, right?
so if this magnet gets shifted
then it'll short out + and -.
britney spears what :O :crackup:
Indeed they do - in your application - and so you are 100% correct.
I see why people are so dead against them.
In mine there will be some ~3/4" tube with a machined plastic 'bung' at either end into which a spring will be inserted with a wire soldered to the spring.
So +ve and -ve ends of the battery pack will be about 200mm apart (with x3 18650's).
Battery spacers help you insert non-standard cells in the next-size-up charger.
That is a pretty good illustration of the potential problem - definitely something to be wary of. Obviously adding a blob of solder to the +ve terminal on the light would be WAY safer.
