The http://www.dealextreme.com/details.dx/sku.11074 http://www.light-reviews.com/dx_sku_11074/ may be a more suitable drop-in for a single cell configuration compared to the DX 11836.Has anyone tried the batterystation 17670? I want to put it in my surefire 6p w/ DX 11836 R2 drop in module. I am wondering if it will give me more output and or extended runtime all while being rechargeable. Anyone know?
:thinking:
Most of us use AW brand protected 17670 cells for that type of application. I don't know much about the batterystation 17670, but their protected RCR123s are good.
Ideally, try to find a module that is designed around the voltage range of a single li-ion cell, they are typically listed as something like "2.7-4.2V" compatible and will likely have more stable regulation. The module that Flashfirstask?later linked to is a more suitable option.
The MalkOff M60 is a buck-regulated module and requires an input voltage slightly above that of the Vf of the LED at the drive level of the module to stay in regulation. The MalkOff modules will run on a single li-ion cell, but they will drop out of regulation part-way through the discharge.
The M60 is best driven on 2xCR123, or 2xRCR123, or in a larger body with say, 2x17500/18500/18500/18650 (depending on body available).
My understanding is that MalkOff also makes a module called the "M30" that has a boost/buck style regulation built in that will run on a single li-ion cell (like a 17670) and stay in regulation. it's a special order item only at this time from my understanding...
IMO: just stick with what you have there.
Thank you for the info.
Not to sound to stupid but can you explain to me what you mean by "drop out of regulation" and what happens if a LED does that.
wvguy, just wanted to add my two cents... I currently have a SF 6PD w/ M60 drop-in and I use an AW 17670. I've had the light on for 30-45 minutes constant intervals (night-time, mountain-biking) without any noticable dimming and, to my eyes, the output appears to be about the same as using 2xRCR123's - I can't tell but there *might be* more output with the 2RCR's due to the higher voltage.I have a question for you. I'm currently using a Surefire 6p with a malkoff M60 drop-in and two AW protected RCR123s.
would there be any advantage to switching to the AW protected 17670?
