Battery stuck in E01
Fireclaw18
Put some goggles on and drill that ***** out of there.
If lubricant doesn't work, this is probably your only option.
This is also why you should never put alkaline batteries in flashlights. Spend a little more and buy Energizer Lithium primaries. Those never swell up.
Brlux
Mesa, AZ
I know this is a really old thread but if anyone suffers a leaked Alkaline battery the only thing I have found to really remove the corrosion is CLR. that stuff just eats up battery corrosion. I had a 1AA Dorcy light with an aluminum body that I liked have a AA get stuck in a similar manner. I just filled it up with CLR, let it bubble, dumped and repeated the process a few times. It ate up most of the corrosion and I was able to tap the battery out.
I also got a Used Wii game console that had leaked batteries in the remotes. CLR on Q-tips quickly cleaned them up. I have never had CLR damage electronics that were submerged in the stuff but use at your own risk. You could always rinse with distilled water to be sure to get the CLR out with out damaging additional things.
Burgess
USA
The new E01 is supposed to be brighter...
13 lumens versus 10 on the older ones. Any comments?
Yes indeed, the " new " Fenix E01 lights are significantly Brighter !
However . . . .
In my testing, with Energizer Ultimate Lithium L92 batteries,
- Old type lasted 13 Hours, in perfect regulation
- New type lasted 10 Hours, in perfect regulation
Just for your information
