Simon welcome to the group. Stingray has some good suggestions for you. However your question was only half of the whole question you should have asked. For instance Stingray's of the G2 with P61 lamp and 6P with the extender and P91 lamp only told you half the story. The runtime on these lights is only about 20 minutes on a set of lithium batteries costing $2-$14 depending on where you buy the batteries. Do the math that is $6 - $42 in batteries for an hours worth of light!
Is that what you are prepared to spend?
I answered a question from a newbie a few days ago to help him get started and give him a little more info. I'm going to repost it here for you cause I have a feeling it may help you also;
These generalizations are true in the vast majority of circumstances (but there are exception to each one of these)
1) Brighter the light, the shorter the runtime!
2) LED's come in two types, smaller 3 or 5 mm diameter with outputs of 1-3 lumens each OR Luxeon Star LEDS made by Lumaleds with outputs around 17-30 lumens each.
3) Incandescent lamps (regular light bulbs) still kick LED's butt if you want to throw a beam of light beyond about 30 feet.
4) Surefire Lights are Tactical lights, not general purpose lights for the homeowner. As such they are usually purchased (except for CPF members) by taxpayers for issue to special people who do tactical things.
5) Textured reflectors produce a smoother beam that smoothly polished reflectors.
6) Adjustable focus is a lie. There is only one focal point, you are de-focusing a light. Marketing people love this bullsxxx. Some people find the feature helpful anyway, when they need a less intense light. Me I set the focus to the least annoying beam shape and then never fiddle with it again.
7) Flood v Spot. 90% of people should buy a flood beam that throws no more than the length of their backyard. Questions like "Hi I'm new here and I want a flashlight with a tight spot that lights up a tree 300 yards away to impress my friends, what do you recommend" makes me roll my eyes and say to myself here we go again.
8) Lithiums are really not that more expensive and kick alkalines butt for several reasons, however they are harder to find. Buy from Surefire or other vendors here on CPF ($1-$2 each)
Good luck and welcome,
GregR
Well looks like I have to add something already. There is no easy chart or conversion formula between Candlepower and Lumens. Lumens is the total amount of light produced, whereas Candlepower as typically advertized is the brightest part of the beam. So while they are related Candlepower is often misleading and can be used by market departments to hype their products. That is why some manufactures say Lumen is a more honest means of measure light produced. To give you an example of how Candlepower can be manipulated, take a laser pointer for example. I would imagine even a cheap one is probibly a million candle power yet it makes a horrible flashlight, because the amount of light (lumens) is really small.
