Best Do-Everything Charger
Flashlight Aficionado
I looked at Silver Fox's Charger Comparison and found the Schulze isl 6-330d-RS. It seems to be the best charger. But the thread is six years old and I can't tell if it can automatically recognize which battery type attached.
So what is the best around today?
1. Price is no limit. But don't jump to the highest price because I said this.
2. It must charge every chemistry.
3. I really want a battery chemistry auto detect.
4. I can charge multiple cells independently. Different chemistries at the same time would be great, but not necessary.
:thanks:in advance.
The following posts were recovered from cache data.
Re: Best Do-Everything Charger
Written by TranceAddict on 02-18-2011 04:47 AM GMT
complete list ofhobby charger in comparison and pricing details:
http://www.progressiverc.com/Charger.html
your question is easy to answer :)
1. best charger on earth: Schulze next-14-500 http://www.schulze-elektronik-gmbh.de/index_uk.htm
2. yes it charges all commonly available chemistry, Ni-Cd, Ni-MH, Lead-Acid, Lead-Gel, Li-FePo4, Li-Ion, Li-Po
3. such feature will never exist for hobby charger because battery pack usually has very different configuration in series and parallel, this limitation makes it impossible to detect cell characteristic to determine which chemistry in use. and for safety measure it should be avoided.
4. it has 2 independent output channels, each can charge up to 7 cells in series with balancing leads connected, but only same chemistry can be connected to the same channels. Charging in series with balancer is very similar to charger with independent charge slot, each cells will be balanced and cutoff nicely
Written by CKOD on 02-18-2011 05:30 AM GMT
A price level(or 2) down from the schulze would be the FMA/Revolectrix cellpro multi-4. Nickel, Lead, and Li-Ion and LiFe cells, upto 4S for balanced Lithium charging, 10s IIRC for nickel batteries. One channel output, but its a 4Scharger, not much point in splitting it to 2 and 2. If you have identical batteries no reason you cant series them if they are in a similar SOC.
and I'll agree, there should never be an auto chemestry selector. Even with a balanced pack so it knows the actual V/cell, it could end up bad if whatever charger you have mistakes a LiPo cell for a 26650 A123 cell, and gives it 10+ amps. I mean they (chargers in general) cant even get non-balanced auto cell number selection on li-po batteries right, you cant expect them to guess the chemestry right too.
The Cellpro multi 4 makes you confirm the chemestry and for non-balanced packs (A123 nickel and lead, it doesnt support non-balanced li-ion) it also makes you confirm its guess on how many cells there are, before it even starts to charge.
Written by HKJ on 02-18-2011 06:27 AM GMT
TranceAddict said:
complete list of hobby charger in comparison and pricing details:
It is not complete, none of It is not complete, none of my hobby chargers are on the list.
Maybe, but it is definitely one of the most expensive. I like the iCharger, but you get many of the same functions in even the cheapest Maybe, but it is definitely one of the most expensive. I like the iCharger, but you get many of the same functions in even the cheapest hobby charger.
Written by clintb on 02-18-2011 11:09 AM GMT
Schulze is living in a dream world these days. Their topcharger, with VAT, converted to USD is $818. Tell me, why on Earth would anyone ever pay that much for a charger that can only do 580W total (paralleling the outputs), with a 24V input?
I would much rather purchase one FMA PowerLab 8 that can do 1344W (40A) on 24V input into 8s lithium. Network two of them and you're still well below the price of one Schulze.
Written by 45/70 on 02-18-2011 12:13 PM GMT
Just to throw in an opinion here, you're never going to find a "best" all-in-onecharger that will also charge nickel based cells, unless you only charge welded NiMH/NiCd packs. I'm all for the hobby charger solution for an "all-in-one" charger, otherwise. To effectively and efficiently charge individual nickel based cells also, you're going to have to have two chargers. Hobby chargers just don't work well for charging nickel based cells unless, they are configured into "packs" where you have no other choice but to charge them in series.
Yes, you can set your individual nickel based cells up into series and charge them with a hobby charger, but you'll never really know what's going on with each individual cell. This will reduce the serviceable life of these cells, compared to using a dedicated independent channel charger for individual nickel based cells.
Unless you always charge your nickel cells at a 0.1C rate with your hobby charger, some cells are going to consistently be over charged, and some will be undercharged. This is the major disadvantage of charging nickel based cells in series. Keep in mind that hobby chargers are primarily designed for charging "packs" for R/C use (R/C, is the "hobby" in "hobby charger"), not individual cells.
Dave
Written by BVH on 02-18-2011 02:20 PM GMT
clintb said:
Schulze is living in a dream world these days. Their top charger, with VAT, converted to USD is $818. Tell me, why on Earth would anyone ever pay that much for a charger that can only do 580W total (paralleling the outputs), with a 24V input?
+1 on the +1 on the PL8. I have the 10.36-12 Gen 1 Schulze and just got the PL8. So many more adjustments (more parameters and much finer values to select) on the Pl8. The Gen 2 Schulze top of the line dropped their internal discharge capacity to 50 watts ea on two channels or 100 watts both channels parallel'd. Two Pl8's, in my opinion, would be far more versatile and powerful than one gen 2 Schulze top of the line.
Written by tandem on 02-18-2011 09:16 PM GMT
Another +1 on thePL8. If one is spending near the 200 dollar range, a few dollars more for this one won't seem misspent. Great charger and battery management system but it doesn't meet all the slice and dice and puree requirements the OP listed.
As none really do, the best do all charger is probably three or four chargers.
Written by Flashlight Aficionado on 02-18-2011 10:29 PM GMT
Since the auto-detect is out and I was willing to pay more for that convenience, I will change my requirements.
Say around $300.
It still must charge every chemistry.
It can charge multiple cells independently or balance charge them.
You guys like the PL8 (FMA PowerLab 8).
Another +1 on the PL8. If one is spending near the 200 dollar range, a few dollars more for this one won't seem misspent. Great charger and battery management system but it doesn't meet all the slice and dice and puree requirements the OP listed.
What doesn't it do? What doesn't it do?
That sounds great. Since I can't auto-detect, a little verification prompt is nice. Does the That sounds great. Since I can't auto-detect, a little verification prompt is nice. Does the PL8 do this too?
Written by CKOD on 02-18-2011 10:49 PM GMT
45/70 said:
Just to throw in an opinion here, you're never going to find a "best" all-in-one charger that will also charge nickel based cells, unless you only charge welded NiMH/NiCd packs. I'm all for the hobby charger solution for an "all-in-one" charger, otherwise. To effectively and efficiently charge individual nickel based cells also, you're going to have to have two chargers. Hobby chargers just don't work well for charging nickel based cells unless, they are configured into "packs" where you have no other choice but to charge them in series.
Dave
Good point, In fact isnt the preferred termination method for newer nickel cells delta temp/time instead of dv/dt? Since the voltage sag which can be missed is caused by an increase in the temp? Seriesed cells for charging which weren't discharged seems like it would always be sub-optimal. and for good dtemp/dtime you'd want a temp sensor embedded in the pack rather then just a temp sensor on the other side of a plastic cradle. Good point, In fact isnt the preferred termination method for newer nickel cells delta temp/time instead of dv/dt? Since the voltage sag which can be missed is caused by an increase in the temp? Seriesed cells for charging which weren't discharged seems like it would always be sub-optimal. and for good dtemp/dtime you'd want a temp sensor embedded in the pack rather then just a temp sensor on the other side of a plastic cradle.
Written by BVH on 02-18-2011 10:59 PM GMT
ThePL8 is not multi-channel but is a balancing charger and supports parallel charging. And you place a big emphasis on "all chemistries". The PL8 does that now and....it is firmware upgradable for future chemistries and for the new, higher Voltage Li-Ions predicted to be out.
Written by tandem on 02-19-2011 07:18 AM GMT
FA, thePL8 (and probably many other brands) also puts up a verification prompt whether you start the charge through software on your computer or directly on the front panel.
With all of these hobby chargers you are given enough rope to hang yourself with; if you select a Pb program for a li-ion cell and fail to recognize this when you hit the LiPo OK prompt, you are not likely to be happy with the result. FMA seems to take safety seriously enough. Earned or not, they have a reputation for that in the RC world from what I've observed.
Balance charging: yes; you can charge up to 8 li-ion / lipo cells in series with balance taps, and do so at higher rates. The balance current maximum is 1A which is higher than most if not all other chargers in its class. This isn't likely a big deal unless you are charging high capacity lipo packs at high rates of charge, as some RC folks do / sometimes must do.
If you were considering balance charging li-ion cells in series, you'd need to make up a pack with taps; the proper connector with bare leads can be purchased along side the charger. However if the cells are loose you'd be better off simply charging them in parallel.
Note: NiMH cells can't be charged in parallel, but can be charged in series and do not require balance taps but should be charged slowly in series packs for max life.
Whatever you do be sure you get a device which can have its firmware upgraded in the field. The iCharger and FMA PL8 and FMA Cellpro Multi 4 offer this ability; others may, you'll need to check.
What can't it do? It isn't multi-channel. I don't find this to be a problem myself. In some respects I bought it because it is single channel, perhaps in the naive belief that they'd invest in higher quality output components for a single channel device. It being a 1344W charger, a robust output stage should be a given.
Mostly I'm using mine for charging 18650 cells singly or in parallel arrangements; my 18500's I mostly relegate to the Pila I have; for radio control - charging of 2S and 3S (eventually some larger configs in my future) lipo battery packs singly and in parallel - all balanced charged; and some limited NiMH pack cycling. I do have plans to add a lead acid battery into the mix here. I also appreciate being able to do discharge and cycle studies with it.
Multi-channel or not one thing you'll be looking for is a wide variety of connectors, perhaps some rare earth magnets, DIY cell cradles, flexible hook up wire, etc. as you fabricate items to make your charging centre more useful.
You'll also need a power supply for most chargers being discussed in the thread; if you really want or need a PL8 and want 1344 watts out you'll need a significant power supply - 24V, high current, and that will run you some coin. I'm driving mine with a 10A bench supply so my max output power is far from 1344 watts but is ample for what I'm doing at present, but won't be sufficient for driving the charger to handle the power required for larger numbers of larger capacity lipo packs in parallel. I do have a 12V server power supply sitting idle here waiting for me to get round to converting it to drive the charger.
PS: Charging a few 18650 cells at 0.3C or 0.7C or 1.0C doesn't require a lot of input or output power. Singly we are talking just a few watts and in parallel you can add a few watts up and get to not many 10s of watts input required. For a lot of what I do my 130 watt bench supply is more than sufficient and in fact I really only need really high output when at the flying field if I were charging many packs in parallel at high rates which is not the norm for me at all, least not at this point.
Written by SilverFox on 02-19-2011 03:32 PM GMT
Schulze built their reputation on charging nickle based battery packs. Their Auto algorithm does wonders on packing more into the pack, and also it seems to hold the cells in balance longer.
I have several pieces of test equipment that run on nickel based battery packs, and I have been totally impressed with the performance of the Schulze charger to keep them in very good shape. I have seen a 12 - 15% increase in run times over the chargers that came with the equipment.
Now that the emphasis seems to have moved to Li-Ion chemistries, I am not sure the Schulze holds any "advanced" algorithms in that area, but I haven't kept up on their advancements.
The reasons I purchased my Schulze,
High quality.
Ability to charge lead acid chemistry, and it does a very good job at this.
Ability to charge Li-Ion chemistry. It does a pretty good job at this, but is subject to lead wire and connection resistance.
Ability to charge two different packs at the same time. While channel 2 charging is limited on my unit, I have used it often and find it very useful.
Ability to monitor the charging progress on my computer.
And finally, and most importantly, the ability to charge large numbers of nickle based cells and pack more into them than other chargers can. I also find the long term forming function very valuable in recovering abused battery packs, and have used it to break up minor sulphation in lead acid batteries.
That's my $0.02 on the Schulze.
Tom
Written by CKOD on 02-20-2011 12:56 AM GMT
Another thing to note, if you want the full 1kw+ discharges with the Another thing to note, if you want the full 1kw+ discharges with the PL8, then you need a battery for it to dump the load into. So if you want to do heavy battery cycling, then a nice SLA or 2 may be of interest. Plus you could use a cheaper lead acid charger and let the battery handle the 50+A current the PL8 needs for high power pack charging. You could even just use a cheapie power supply and use PL8 to charge your SLA bank after its done charging your other cells from the battery. :duh2:
Or you could use an electronic load to sink the current from the PL8
http://www.bkprecision.com/products/...onic-load.html :duh2:
Written by 45/70 on 02-20-2011 08:52 PM GMT
Your points highlight the shortcomings of series charging nickel based cells. Ideally, a Your points highlight the shortcomings of series charging nickel based cells. Ideally, a charger should always have more than one way of determining charge termination for each cell. Unfortunately, there isn't really any way to do this when charging nickel based cells in series, or at least any way that is practical.
If a balancing setup could be implemented, similar to how Li-Ion cells are charged in series, it maybe could work, but would be much more complex, having to monitor each individual cell for both -dV, and temperature, for example. It could probably be done, but I can only imagine what the cost of such a charger would be. :eek:
Dave
Written by hazna on 02-21-2011 02:47 AM GMT
Are there any reasonably pricehobby chargers that can detect the -delta V? I recently bought the accucell 6, but am dissappointed it can't detect -delta V and misses termination. I now set termination when expected capacity is reached... however I feel I need to fully discharge my battery if I am going to do this.
Written by HKJ on 02-21-2011 03:32 AM GMT
hazna said:
Are there any reasonably price hobby chargers that can detect the -delta V? I recently bought the accucell 6, but am dissappointed it can't detect -delta V and misses termination. I now set termination when expected capacity is reached... however I feel I need to fully discharge my battery if I am going to do this.
Have you tried adjusting the DV threshold? Have you tried adjusting the DV threshold?
Written by hazna on 02-21-2011 04:03 AM GMT
yeah i've tried adjusting it down to 5mv, which seems to be it's lowest setting. No luck, though
Written by zehnmm on 02-21-2011 07:37 AM GMT
+1 on the Schulze. I lucked out and found mine from Ebay for a song. Same thing for my Mastech power supply.
Written by 45/70 on 02-21-2011 09:20 AM GMT
I've found that when charging 2-4 cells, a 5mV -dV works most of the time. When charging 6, 8, 10, 12, or 13 cells though, any more I charge at a 0.5C rate. When I notice any area of the pack starting to get warm, I stop the charge, reduce the charging current to 0.1C, then resume charging at the lower rate. I've found that when charging 2-4 cells, a 5mV -dV works most of the time. When charging 6, 8, 10, 12, or 13 cells though, any more I charge at a 0.5C rate. When I notice any area of the pack starting to get warm, I stop the charge, reduce the charging current to 0.1C, then resume charging at the lower rate.
Sometimes, with newer cells, the charge will terminate by -dV without any cells getting hot. Particularly with older packs however, I simply charge the pack another couple hours at the 0.1C rate then terminate the charge manually. Otherwise, some cells will get really hot, with some cells obviously missing termination even at 5mV -dV.
Dave
Written by Battery Guy on Unknown
What about chargers that don't require a DC power supply? I would like to buy acharger that is capable of balance charging a 5 or 6 cell series string of lithium-ion cells, and up to about 24 V for NiMH packs, but I want to be able to plug directly into 110 AC. I would also like the ability to select the cut-off voltage for lithium-ion charging. Anything out there that can do this?
Cheers,
BG
Written by HKJ on Unknown
Battery Guy said:
What about chargers that don't require a DC power supply? I would like to buy a charger that is capable of balance charging a 5 or 6 cell series string of lithium-ion cells, and up to about 24 V for NiMH packs, but I want to be able to plug directly into 110 AC. I would also like the ability to select the cut-off voltage for lithium-ion charging. Anything out there that can do this?
Cheers,
BG
A hobby charger with buildin power supply. There are some, you just have to look around.
Written by tandem on Unknown
Hyperion and Thunder Power both make AC/DC powered chargers and both are probably better than the usual Bantam clones you'll find out there. Bantam also has a couple AC/DC chargers in their line up.
Whether or not it is due to the cloning of the Bantam line and thinning out of their market share, Hyperion and Thunder Power seem to be somewhat more popular in the RC crowd at present. Both of the latter also make highly regarded lipo battery packs which may also in part be why. Thunder Power packs tend to be regarded as the king of the hill right now, and command prices to match the reputation.
If you narrow your choices down and do a search on rcgroups.com no doubt you'll find some validation.
Written by 45/70 on Unknown
Back when I was reading through the R/C forums researching Back when I was reading through the R/C forums researching hobby chargers, there were two things that were recommended to avoid. Chargers with fans, and chargers with a built in power supply. It seems these are the first two items to fail in the more inexpensive chargers, <$100. Having some insight as to the quality of charger you're most likely looking at BG, this probably isn't a problem for you. The higher end chargers likely have better components and these two items probably are not much of a problem.
As for the ability to select Li-Ion CV stage voltage, most chargers are pretty much limited to 3.6, 4.1, and 4.2 volts (LiFe, LiIo, and LiPo respectively). Some chargers have an adjustment available for this voltage, but as I understand it, it is only +/- a few hundredths of a Volt.
Most hobby chargers also have a "fast charge" mode, which I usually use, which the only difference is that charge is terminated at C/5 instead of C/10. This effectively terminates the charge in between 4.10 and 4.20 Volts with LiCo (or LiPo) cells when the CV voltage is set to 4.20 Volts, or "LiPo" (and I suppose 4.00 and 4.10 Volts when set to 4.10 Volts, or "LiIo").
Also, most hobby chargers offer a "storage charge" mode which charges (or discharges) cells to 3.30, 3.70, or 3.80 Volts (LiFe, LiIo, LiPo). So anyway, there is some flexibility with these chargers, but I imagine you'd have to go to a higher end charger to gain much more range as far as setting a custom CV voltage.
Dave
Dave,
Poor quality clones probably have more to do with one aspect of the advice you've seen given on RCGroups - fans. Only chargers limited to fairly low rate charging would be shipped without fans these days. The Bantam clone units like the Accucell all appear to have fan noise issues but many add a drop or two of lube and the problem seems to go away. Fans are fairly cheap and easy to replace at any rate. I've no solid sense of how Bantam units themselves are held by the community but I have noted lately in discussion on RCGroups both clone and original units implicated in balance charging failures (in my mind) with one cell in a pack reaching 4.5 - 4.8V. No matter what the cause this seems like a bug and a surprising one at that.
As for AC/DC chargers as long as properly built they have a place, but likely are not endorsed as often as they tend to be limited in output power and therefore wouldn't be a good fit for someone needing to charge numbers of larger capacity packs at high rates or especially at high rates in parallel which is definitely the trend of late. It is easy to run into max power output limits on entry level 50W chargers even for those flying nothing but small foam craft with modest power requirements - many of these are powered by 2S packs with < 1000 mAh capacity. Sure you can charge a handful of these in parallel at ~ 8W output required per pack with even a relatively modest charger... just not at high C rates. AC/DC chargers usually offer more output on DC input though which may help some. Also... when charging at home usually one is in less of a hurry than when at the field.
It isn't clear to me that the Hyperion - ~ $120 - $280 depending on model - has the flexibility for max voltage threshold BG seeks but I think it does; I find their manuals poor. It could be / probably is the parameter "TCS Capacity" (measured in percent) is how you manage this with their charger; I rather prefer to set it by nV per cell. The ThunderPower 610C - ~ $100 - also uses a percentage figure as does the Korean made Bantam BC6DX-II - ~ $150 up - (and higher max output power BC8DP). As far as I know all three feature user-driven firmware updates.
Thanks for the info gents. It is really very helpful.
Currently I am considering the Hyperion HP-EOS0720i NET3 AC/DC. Since I am not into RC hobby racing, I don't think that I need to have two independent charging channels, so the DUO seems over kill.
Anyone see a down side to this charger?
Thanks for your advise.
Cheers,
BG
Dave,
Ah, yes, you're right. I was thinking about <50 Watt chargers like I have (a cheap clone). Of course, BG is looking at something quite a bit larger and yes, it would no doubt require a fan. Ah, yes, you're right. I was thinking about <50 Watt chargers like I have (a cheap clone). Of course, BG is looking at something quite a bit larger and yes, it would no doubt require a fan.
As for the <50 Watt chargers, there really isn't any need for a fan, provided the heat sinking is adequate, IMO. These are transistors being cooled, not processors. They are designed to run hot, very hot. With more than 50 Watts or so though a fan would probably be needed, particularly in the interest of keeping the charger relatively small in size. Passive heat sinking can only go so far.
IMO, regardless of the size or quality of the charger, you're way ahead to keep the charger and the PS separate, for heat issues, if nothing else. That may just be my way of thinking though. I always buy separate components for my high end audio. It's the amp that always fails first, so why not keep the major heat source away from everything else, for example.
Dave
Dave
Oh how I truly the miss the days of matching audio components. Remember how important it was to match your stylus to your tonearm to your turntable? And playing a beloved song was a ritual involving cleaning of the stylus and the vinyl? The music seemed to sound better back then, even if the technology was primitive. Perhaps I am turning into an old fart. Oh how I truly the miss the days of matching audio components. Remember how important it was to match your stylus to your tonearm to your turntable? And playing a beloved song was a ritual involving cleaning of the stylus and the vinyl? The music seemed to sound better back then, even if the technology was primitive. Perhaps I am turning into an old fart.
Well Dave, I think that you and I have a lot in common with respect to audio, because I still have separate components. But when it comes to charging my flashlight battery packs at home, I am inclined to go for the "receiver" instead of the "amp/pre-amp/tuner" option. I have access to high end battery test gear as part of my normal job, so I really just need something that is reliable and safe for home charging of battery packs.
Any negative issues with the Hyperion that I should know about?
Cheers!
BG
Music is an analog experience, at least if you play "real" instruments it is. And yes, that includes electric guitars. So the music Music is an analog experience, at least if you play "real" instruments it is. And yes, that includes electric guitars. So the music did sound better. :) Also, you forgot to mention the disk preener!
Actually, I'm presently looking into a turntable. Also, tube amplifiers. The biggest problem I had when CD's came out was that cymbals sounded more like garbage can lids than cymbals!
Dave
Written by KiwiMark on Unknown
The iChargers have the ability to set the CV stage voltage, by more than a few hundredths. The iChargers have the ability to set the CV stage voltage, by more than a few hundredths.
LiFE - 3.40V-3.90V
LiIo - 3.90V-4.20V
LiPo - 4.00V-4.30V
For this feature and a few others that aren't on the cheaper chargers I have just ordered an iCharger 106B+ for under $100 shipped. I think that if you include the price in the equation this could be the best charger available (depending on what features you want/need) and I'd rather buy 2 of these than one of the dual channel Schulze chargers (because the Schulze chargers are just too expensive for me). I also wanted to be able to charge at 0.05A which the iCharger can do, but the cheaper chargers usually only go down to 0.10A which is a bit high for some tiny batteries, 0.05A to 10.0A seems like a pretty flexible range of charging current to me. The iCharger comes with a temperature probe which is nice for another cut-off option for better safety, you then have time, temperature & capacity cut-off options available which you can disable or enable and set parameters for.
For the best charger I'd recommend:
On a tight budget I'd recommend the Turnigy Accucell-6 at $23 + shipping. It's a really good charger with lots of great features for a great price.
On a higher budget I'd recommend the iCharger 106B+ for $80 + shipping. It's a better charger with better features, obviously you have to pay more for it.
On an unlimited budget the Schulze chargers look to be the best, but of course you pay so much more for them.
My own charger configuration:
iCharger 106B+ (on the way)
Turnigy Accucell 8 (bought back when it came with the thermal probe)
2 x LaCrosse BC-900 chargers (I've had them for a few years and have never had a problem, each can charge 4 x AA/AAA NiCd/NiMH with 4 independent channels and settable charge current)
2 x WF-139 (each have 2 independent channels, but I don't use these much - my hobby chargers are better)
Yeah, I can get a lot of batteries charged in a fairly short time.
I have a computer PSU that provides power to my 2 hobby chargers, they can also be powered by any car battery if needed. (they can also charge a car battery with the Pb setting)
Correct me if I am wrong, but the iCharger 106B+ does not operate off of AC, correct?
I'd agree that these are the 2 main failure points, but I've found that with a couple of drops of Nano-Oil my cheap fans have been OK and it wouldn't really take much to replace a fan. I'd agree that these are the 2 main failure points, but I've found that with a couple of drops of Nano-Oil my cheap fans have been OK and it wouldn't really take much to replace a fan.
The power supply thing I kinda agree with, at home I've got a computer PSU that didn't cost me anything that can easily power 2 hobby chargers - so I just don't need a built in AC power supply. If I go car camping or hunting and want to take a charger so I can charge from the car battery then the hobby chargers without a built in AC power supply will be smaller & lighter - and the AC power supply won't be needed. If I am staying at friends' houses or at motels or anywhere else that will have AC power and I want to take a hobby charger then I can just take a separtate power supply - similar size & weight in total and I can buy a hobby charger + power supply cheaper than the models that come with a built in power supply - also with a wider selection of hobby chargers to choose from.
However if someone wants a charger with built in AC power supply and finds a model that they like with that feature then the odds are that they'll have no problems with it.
You are correct - you would need a power supply + iCharger to run from AC. You are correct - you would need a power supply + iCharger to run from AC.
I really don't see how the 2 separate components would be much different to having one unit with built in AC power supply, many of my other devices have a wall-wart or other PSU outside of the device itself. i.e my HP printer, my 3.5" external HDD enclosures, my LaCrosse BC-900 chargers, my laptop computer, etc.
Separate PSU & charger also keeps the power supply heat away from the hobby charger.
# -- end of recovery --
I know this is kinda old, but I just picked up a used schulze next 10.36-12 for $180. Seems like a really good deal from what I have been reading. What do you guys think? :twothumbs
I'm sure I will never use most of it's capabilities, but compared to newer hobby chargers, the price seemed good.
