I am planning to mod led lenser K3 w/ red XPE. Vf is 2.1V @350mah and 2.3V@700 mah (max). It will be powered by single 10280.
My req:
>It has to be tiny because the only space is between Led PCB and pill. see 4th and 5th pic:
http://www.candlepowerforums.com/vb/showthread.php?t=244570
>It has to be as efficient as possible.
I am considering TPS62225 buck converter. It is small and requires only 3 other parts: inductor, input capacitor and output capacitor.
High-Efficiency Synchronous Step-Down Converter With up to 95% Efficiency
2.5-V to 6-V Input Voltage Range
Fixed 2.2 Output Voltage
Up to 400-mA Output Current
1.25-MHz Fixed Frequency PWM Operation
Highest Efficiency Over Wide Load Current Range Due to Power-Save Mode
15 µA Typical Quiescent Current
Soft Start
100% Duty Cycle Low-Dropout Operation
Dynamic Output-Voltage Positioning
Available in TSOT23 Package
http://focus.ti.com/docs/prod/folders/print/tps62225.html
>Over discharge protection/warning. The above regulator needs min 2.5Vin. what happens when the battery voltage drops below 2.5? will it cut off or drop Vout below 2.2v to give some kind of warning?
>This not a req but would be very nice to have: modes. Any idea how I can implement this? I have seen this only in current regulated drivers so I am not sure if it is even possible w/ above buck converter. Is there any current regulator that would meet all my req and offer modes??
Thanks for your help.
My req:
Soft Start
