DM51
Lol, thanks Gatsby. On re-reading my post, I suppose it did come across as a little peremptory.
This is because we get threads identical to this one every few days, and every single time there is someone who pops up to put forward bad advice (vaseline / petroleum-based products) instead of good advice (silicone grease). You were right to point that out.
There are some questions which bear repeating every now and then, such as "which light do you keep in your car?" or "what keychain light?" because new lights come out and people's choices change.
The same is not true of questions about what lube to use on O-rings. The advice has not changed, and it won't. Every diver knows that. And a simple search would have thrown up the dozens and dozens of threads on this issue, each one pretty much identical to its predecessor.
And it DOES matter to use the right stuff, as in some cases lives depend on O-rings not failing – and fail they eventually will, if people use petroleum-based products on them.
