Big, cheap thrower
CheetoFactor
I'm looking for something big and cheap to spot small critters/show off with.
Probably XM-L, not worried about form factor.
So far I'm leaning toward the FandyFire STL-V6/Sky Ray STL-V2.
_X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
_X__Up to $50.
3) Format:
_X__I want a flashlight (hand held/self contained).
4) Size:
_X__MEDIUM - Holster/belt ring carry. (>7 inches)
_X__LARGE - Big enough to need its own travel case.
_X__I don't care.
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
_X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
_X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
_X__I am interested in assembling my own components. (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source).
_X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
_X__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_X__I want search and rescue type illumination (800+ lumens).
_X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
_X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
_X__Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
_X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
_X__Slightly Important (Walks around the neighborhood).
_X___Any size switch will do.
_X__I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
_X___I don’t care.
