I have seen a higher than normal number of emails with customers not achieving full output under high power factor conditions.
I have found that the current batch of Blue Sharks were loaded with a inductor of wrong value. The inductor used is a 6.8uH inductor and it should be a 4.6uH inductor.
If you plan on driving with an input to output ratio higher than 2:1 and expect input currents to rise above 2A you should return any unused converter boards and get an exchange for new ones.
There is nothing wrong with using this inductor except for the fact that the 6.8uH inductor generates more heat and this additional heat on the board will heat up the IC and cause it to thermally shut down. Continuous thermally shutting down will eventually cause the IC to fail.
Effective today June 11, 2010 any Blue Shark shipped will have the correct inductor installed.
If you have any questions you can post here or send us an email.
To date an estimated number of Blue Sharks shipped is somewhere in the ballpark of 30 or so plus some quantities shipped to other customers with larger volume.
Wayne
Wayne
