Hello All,
After receiving great advice both here and in the general forums, I purchased a Fenix TK-40, a set of 8 Eneloops, and a Maha MH-C808M.
My question:
When I first receive my Eneloops, is there any "breaking in" required/recommended before they're used in the TK-40.
I am a noob, both in batteries and lights, and understand that the MH-C808M has a conditioning feature, but wanted to check with you guys first before using it.
Thank you to everyone in advance!
-Glass
Ideally, you would want to break-in your Eneloops with a few break-in cycles in accordance with the procedure set down in the Eneloop specifications:
As noted above, the specifications call for a few 16 hour charges at 0.1C (200mA), each followed by a deep discharge at 0.2C (400mA) to 1.0 Volts.
Although not noted in the specifications, there are indications that the Eneloop will also benefit from an initial discharge at 0.2C to 1.0 Volts before proceeding with its first charge, whether or not it is part of break-in cycle.
Since most chargers don't provide for a break-in cycle, we can only do our best to approximate the process.
In your case, I would recommend using the TK-40 to discharge your cells at a very slow rate, let them rest for at least an hour, and then re-charge them at your charger's slowest rate. They should also be allowed to rest for at least an hour following each charge. I wouldn't worry about over-discharging your Eneloops with the TK-40 providing they're not left in an over-discharged state for an extended period of time.
After you've run of a few of these ad hoc 'break-in cycles', you may also want to subject your Eneloops to a couple of actual refresh cycles on the MH-C808M to really get them ready for your TK-40 at its most aggressive draw rate.
For more information on the care and treatment of your Eneloops, you can refer to the Eneloop handbook, which is linked here:
http://www.eneloop.info ... eneloop-user-guide.html
There are also the Eneloop FAQs:
http://www.eneloop.info/home/faq.html
Enjoy your TK-40...
