Brightest CR2 lights
blacksheep
Just wondering what the brightest single cell CR2 lights are... I have a few KI-LE and was wondering what else of similar size is going to be brighter...
Thanks
If it ever comes out, it will be the 4Sevens CR2 MiNi. 189 OTF lumens
A Jil JCR2 direct driving a K2 with an RCR2 or if you're conservative using a FLuPIC. I haven't tiried an XR-G yet, but that should be tops. Like mentioned, the CR2 MiNi will probably run a XR-G and will be right up there.
Not the brightest, but the imho the greatest cr2 light with best brightness/runtime ratio would be the Aeon.
114 lumens for 90mins high
10 lumens for 40 hours low
Do you have any photos or how to for your Jil?How about where to get pcb and parts?
Thanx
Is there any CR2 light using modern LEDs? Such as XP-G?
Maybe CR2 lights don't need high output, but very high efficiency.
And small enough.
The Ti MiNi 123 is $69 so expect a similar price for the CR2 model. I'd say under a hundred. There is a special twist on the usual offering that 47s will announce whenever he's ready.
