Ironworker
- Joined
- Oct 21, 2013
- Messages
- 3
I'm an ironworker working nights on the Brooklyn Bridge. I'm looking for a very bright flashlight for work. The work area is lit but I sometimes need to illuminate dark areas of the bridge. Down tunnels and inside beams. I need to be able to look at rivets 50-60 feed down a dark tunnel. Maybe you guys could help point me in the right direction. Thanks in advance for your advice.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
_X___Up to $100.
3) Format:
_X___I want a flashlight (hand held/self contained).
4) Size:
__X__SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
__X__I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____ Doesn't really matter
____I want a light that plugs directly into the wall (literally with prongs built into the light)
8) How much genuine out the front (OTF) light do you want/need?
____I want to illuminate dark areas of the bridge. Tunnels, inside beams (800+ lumens).
__X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
Not Sure. Our work area is illuminated. I need to shine a light down a long dark tunnel to see things that are further away.
__X__Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
__X__Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X__30-50 yards/meters (I have a big backyard)
I work an 8 hour shift but the light would only be on for 5 minutes at a time. Maybe 30 minutes in total per night.
__X__30 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
I don't want a piece of junk.
__X__Very Important (Camping, Backpacking, Car Glove-box).
__X__I don't care.
__X__A simple on-off with only one output level is fine for me.
_X___I don’t care.
14)Material/Finish/Coating
__X__I don’t care.
15) Water resistance
__X__None needed
16) Storage conditions
__X__ Work / home
None
_X___Up to $100.
3) Format:
4) Size:
__X__I don't know.
6) Manufacturer:
__X__I don't care.
_X___I don’t care.
__X__I don’t care.
__X__None needed
__X__ Work / home
None
