Brownin 9V Xenon
dezurtrat
Tucson, AZ
Hey, all, new here. I have probably what is a very dumb question. I was given this Browning 9V Xenon flashlight as a gift. Black Ice.
Says it has Spot-to-flood focus but it doesn't seem to work. All I can think is to turn the top with the lens but it does nothing. Any ideas?
Thanks!
I actually had one of those awhile back. From what I remember, you do turn the head to change the focus.
I remember mine didn't work right away. I had to bend out a contact leaf spring, then it worked okay. I think it was the one that contacted the bottom of the bulb.
Thanks. I can't seem to find anything to bend other than the tab inside the body of the light where the base of the bulb is contacted. I have taken a pic (sorry for the quality - camera phone). Any chance you can point out which part you think you tweaked?
Thanks!
I think it was the part on the top, the tab. Does it turn off when you try to change the focus?
I remember two of AW's protected 17500's fit in the body tube nicely. Made for a good rechargeable option.
Yes, it does turn off when I try to change the focus. I'll give that tab a try.
Thanks for the battery recommendation to. That was my next question!:twothumbs
No problem. The P18500's won't fit, but the tube is loose enough for the P17500's. At least mine was.
