Budget Light Recommendation
smrtprts
Hey guys I am looking for a budget light for a friend who inspects houses. He needs something to look in attics and basements. I was leaning toward a 2 AA or 3 AA alkaline light but if there are not many good ones I could possibly invest in a 18650 charger and batteries for him if it will be much better. Appreciate the help.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
X I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
X Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
X I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
X Every day carry medium (4-7 inches).
X Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
X LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
X I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
X I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
X I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
X 30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
X 90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
X Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
X I don't care.
____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
X I don’t care.
____I don’t know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
X I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Here's a few that are at the top of the price range, or just a couple dollars more. It can be tough to find a decent light without going to overseas long-lead time shipping. If you are willing to wait a bit, there are a few more aa options.
The mini-mag Pro or Pro+ both run 2xAA and can provide > 200 lumen output. Not available in retail yet, but they can be found online. There are a couple of threads about these on CPF so do a search and you can get some hints on where to get them.
Fenix E11 runs 1xAA with ~110 lumen high and a nice low for longer run time. I usually see that at around $27.
If willing to wait, I have 2 of the Sipik SK68 1xAA "zoom" flashlights. You'll see a lot about them in the budget forums. They seem to be regarded as one of the nicer "cheap" lights. They can also be used with 14500 batteries for more output.
If you end up buying a lithium rechargeable setup for him just make sure you read up on the safety precautions on the forum and give him an education too.
Romisen RC-U8 CREE XP-ER5 3-Mode 350-Lumen, it takes 1x18650,2xCR123A,3xAAA. it provides a lot of light and a very good throw for $19.10
U can find it here
DX
SKU 55751
Budget=Shiningbeam
Honestly, if you are on a budget, and not comfortable buying from questionable places on the internets... go to shiningbeam
Bryan is very well respected around here, and his lights are almost top notch, but for the price, I don't think they can be beat.
Edit:
I thought about this a little more... 300-700 lumens on AA batteries.. not gonna happen for $25
I have a Shiningbeam Spark, it's awesome, $40. Bryan is very proud of the Caveman, $40, but I can't comment, I don't own it
The Romisen RC-T601 is crazy bright; cheap too, $30, but it will require an 18650
