Mark_Paulus
Hi,
I realize this is an ambitious project, and might never get off the ground, but....
I was just wondering what would be required to build a light/torch testing station?
Here's what I envision it providing:
for a given time period t, collect light/torch samples every n units (e.g., for a 2 hour period, collect samples every 5 seconds).
spit out the collected results in raw format.
create a graph of the collected units showing lumens over time.
Perhaps be able to graph 2 or 3 different sample sets to show differences.
Would be nice if it ran under linux, and interfaced with a standard serial port.
Maybe this exists, but I think it could be handy to show run time characteristics of different types/brands/styles of batteries, such as:
how do (3) CR123 vs (2) 18650 vs (6) AA vs (2x2) 17670 all compare in initial brightness, discharge curves, and useful illumination curves.
Using these charts, one could easily see how a torch using a type of battery might compare to a different torch using the same battery, or how different batteries affect the light output for the same torch.
Any ideas on which might be required for this type of setup?
I think some sort of photo-voltaic cell for the light measurement, some sort of voltage to digital value converter (an IC of some sort I would guess), a serial plug, and then some program on the linux server to actually query the serial port and take the readings.
If such an animal already exists, I would like to know what it is, and if not, any input would be appreciated.
(Yeah, a really dark room to do the tests would also be needed. Since I have a crawl space, that's not a problem.)
