[FONT="]What would the runtime be with on max power with the following setup:[/FONT]
[FONT="] [/FONT]
[FONT="]3x SST 50s individually controlled by 3 hipcc drivers (1 per LED)[/FONT]
[FONT="]1x D2 flex to allow variable power outputs[/FONT]
[FONT="]5x 18650 cells 2600mAh @ 3.7V in series x 2 in parallel (10 cells in total)?[/FONT]
[FONT="] [/FONT]
[FONT="]I understand the cells alone would give me the following calculations:[/FONT]
[FONT="] [/FONT]
[FONT="]18.5v and 5.2Ah= 96.2Wh[/FONT]
[FONT="] [/FONT]
[FONT="]Could anyone confirm the runtime as I am confused about how much power the drivers will need to run. From the data sheet I can see they require 0.5V to run how would this tie in with the rest of the calculations I need? Thanks in advance [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
