C2 Two Stage Switch
andyross
Isle of Wight
Hi Folks
I have a C2 with a Malkof M60 drop in. Is there any way of turning this light int a 2 stage twisty. Looks like the Sandwich have run out of their conversions. Any ideas where I might get one from.
Cheers Andy
Try a WTB in the CPFMP. I wish you luck. You'll find your C2 more useful than ever. I'm also sad that these switches won't be available anymore:(
There's another option with a Z49/Z59 switch. You can solder a resistor into the switch to make it work with two stages. It's an easy mod but the UI isn't as good as the McC2S switch. Try here... It's a Z57 E-series switch but the concept is the same http://www.candlepowerforums.com/vb/showpost.php?p=1205794&postcount=21
Hope this helps...
