C2H Amp Draw?
Dukester
Washington State
I went to Dereelights Website and there is no mention of how many amps this torch draws? Come to think of it there is also no mention of rated lumens???
The C2H delivers 1A to the emitter, the current draw will depend on the battery's voltage.
Thanks, would you happen to know of the Lumen Rating? Not that it would really matter judging by the beam shots I have seen thus far...
Dereelight doesn't publish lumen ratings, most likely because they don't have the expensive equipment to measure it directly and don't feel like making estimates which may be inaccurate. But you can check my review of the C2H for beam shots. I've got comparisons with the EX10 which is rated at 130 lumens and the Extreme which is rather at 200.
http://www.candlepowerforums.com/vb/showthread.php?t=210598
I took a look at your shots, nice reviews... The CH2 does look brighter than the Extreme with a nice beam with plenty of spill.
It is brighter but it also has 2x shorter runtime.
2C draw is dangerous for RCR123.
here we go, battery draw and lux readings:
  • max 1.4A 4000lux/1m
  • high 0.69A 1300lux/1m
  • mid 0.4A 500lux/1m
  • low 0.1A 120lux/1m
Dave, see sticky in electronics and batteries forum. http://www.candlepowerforums.com/vb/showthread.php?t=117117
Skroll down to Powerizers, and compare to some others.
Bill
Yep, your right Bill, I did take a gander... I bought some Powerizers about 3 years ago to run a 5watt Luxeon and they still work and hold their charge. I did have one give up the ghost but the others are still working out. I will have to order some more from Battery Space. Will wait untill they have the LG 18650's back in stock.
Dave
I checked with AW and he said 1.4A should be safe with his R123's, but that's about as hard as you want to run the cell while still being safe.
Thanks WadeF for checking on that. Glad to hear the C2H isn't pushing the cells beyond their safe limit.
Anyone tried the new AW's IMR16340 rechargeable ?
Specifications :
Chemistry: LiMN
Nominal Voltage : 3.7V
Capacity : 550mAH
Lowest Discharge Voltage : 2.50V
Standard Charge : CC/CV ( max. charging rate 1.5A )
Cycle Life : > 500 cycles
Max. continuous discharge rate : 8C
http://www.cpfmarketplace.com/mp/showthread.php?t=184887
Cheers,
__philippe
Thanks, philippe. I'll have to order some to test them in the C2H. From the graph, it looks like they'll have about the same runtime (~25 min.), but may have a higher cycle life since they can take high loads without a problem. The ability to quick-charge them is also a definite plus! :thumbsup:
