Can you easily remove SF C2 Pocket Clip??
zx7dave
Seattle
I find I don't like the pocket clip on my C2, for that matter I don't care for the one on my E2D either. Are these easy to remove?
Flash_Gordon
NC USA
Yes, they can be removed. Remove the head and the head end o-ring.
I use a loop of paracord about 12" long. Loop under the clip and tug. Usually a few sharp strong tugs will do it. Be aware that there is a small plastic shim under the clip where it is attached to the body. Do not lose it!
One possible side affect is the o-ring tends to squeeze out where the clip was.
Mark
zx7dave
Seattle
So far so good. No O-Ring issues, buit they are not in a wet environment either. Maybe I will put the clip back on and then cut it off at the base with a dremel.
