KC2IXE
Handlobraesing said:Given this, do you know how to read it?
8.7
PhotonBoy said:The vernier is easy; try multiplying 4 decimal numbers using a slide rule.
Nobody misses the slide rule except as a museum piece.
I still prefer analog clocks, but I wear a digital wristwatch since I like its stopwatch function.
elgarak said:KC2IXE, actually, most Vernier calipers I know look like this.
...snip...
That should be the Windows motto.The fastest code is code that doesn't run.
PhotonBoy said:The way to read the scale would be a lot more obvious if the caliper in the diagram were colored-in or a gray tone.
Julian Holtz said:It is definitely 9.7. It does not matter where the edge on the right side lines up with the scale; it matters where the zero lines up with the scale. And it lines up between 9 and 10, therefore 9.7mm.
Cheers,
Julez <--- toolmaker
