Canadian scientists create powerful new lithium battery material
PhotonBoy
Annapolis Valley, Nova Scotia, Canada http://tinyu
http://www.cbc.ca/technology/story/...battery-sulphur-cathode-material.html?ref=rss
"Lithium batteries could deliver more than three times their usual power if they contained a new composite material invented by scientists at the University of Waterloo, a study suggests.
The material created by chemistry professor Linda Nazar and her research team contains sulphur, a cheap substance that scientists have been trying to incorporate into rechargeable lithium batteries for a long time, said a news release Monday...."
That's cool -- it's exciting that there are so many potentially revolutionary energy storage technologies being explored right now. Nanowires, ultracaps, al-air, etc etc.
Since you brought up Li-S batteries, though, I'll mention that there was just an encouraging press release from Sion, who've been working on this battery chemistry for years. Sounds like they've got their sights set on production.
Breakthrough in Lithium Batteries
An article from the Laboratory Equipment trade journal:
Researchers at the Univ. of Waterloo have laid the groundwork for a lithium battery that can store and deliver more than three times the power of conventional lithium ion batteries. The research team of professor Linda Nazar, grad student David Xiulei Ji and postdoc fellow Kyu Tae Lee are the first to demonstrate robust electrochemical performance for a lithium-sulphur battery.
The prospect of lithium-sulphur batteries has tantalized chemists for two decades, and not just because successfully combining the two chemistries delivers much higher energy densities. Sulphur is cheaper than many other materials currently used in lithium batteries. It has always showed great promise as the ideal partner for a safe, low-cost, long-lasting rechargeable battery, exactly the kind of battery needed for energy storage and transportation in a low carbon emission energy economy.
"The difficult challenge was always the cathode, the part of the battery that stores and releases electrons in the charge and recharge cycles," said Nazar. "To enable a reversible electrochemical reaction at high current rates, the electrically-active sulphur needs to remain in the most intimate contact with a conductor, such as carbon."
The NSERC (Natural Sciences and Engineering Research Council of Canada)-funded research team leap-frogged the performance of other carbon-sulphur combinations by tackling the contact issue at the nanoscale level. Although they say the same approach could be used with other materials, for their proof of concept study they chose a member of a highly structured and porous carbon family called mesoporous carbon. At the nanoscale level, this type of carbon has a very uniform pore diameter and pore volume.
Using a nanocasting method, the team assembled a structure of 6.5-nm thick carbon rods separated by empty 3- to 4-nm wide channels. Carbon microfibers spanning the empty channels kept the voids open and prevented collapse of the architecture.
Filling the tiny voids proved simple. Sulphur was heated and melted. Once in contact with the carbon, it was drawn or imbibed into the channels by capillary forces, where it solidified and shrunk to form sulphur nanofibers. SEM sections revealed that all the spaces were uniformly filled with sulphur, exposing an enormous surface area of the active element to carbon and driving the exceptional test results of the new battery.
"This composite material can supply up to nearly 80% of the theoretical capacity of sulphur, which is three times the energy density of lithium transition metal oxide cathodes, at reasonable rates with good cycling stability," said Nazar. The high capacity of the carbon to incorporate active material also opens the door for similar "imbibed" composites that could have applications in many areas of materials science.
Article Source Material: Univ. of Waterloo
Re: Breakthrough in Lithium Batteries
There is already a thread about this in the Batteries section. I'll merge the two.
This would be great! Accept for the poor guy that volunteers to do runtime test's on some 1- lumen modes LOL
If those vent with flame, do they smell like rotten eggs?
Or worse yet, when charging...."Whose laptop cut the cheese?"
Well if they are 3X as powerful as "regular" lithium cells if they vent it will be a very impressive :poof: and when you tell the story to the ER nurse she will go :thinking: then she will wonder why your remaining 3 fingers smell like rotten eggs ;)
