lightliker
- Joined
- Mar 18, 2011
- Messages
- 123
Hello flashlight likers!,
After reading many many posts of the EA4 I almost ordered it untill.... the EA8 came out!! :eek:
Both flashlights have their own advantages where in output there is only a small difference (throw however is MUCH better with the EA8).
I will be using this light on travel and around the house and for having an emergency light in the "once in a year" event of power failure.:poke:
I have a pile of duracell AA's (for emergency cases only on high!, I know!! :D) and will order a maha charger within short time to have a really nice and reliable charger).
The like of the EA8 is the possibility of having real THROW, a long time on turbo, a bit more protected power switch (because of the bigger head), a real low and a very long runtime at the lower settings. Also this light can be ordered in Neutral white.
The dislike is that it's more than 6 cm longer and a bit bigger at the head and the need of 8 AA's.
The like of the EA4 is that it's a little pocket rocket with HUGE output, handy for the wow factor :D (my baton S20 on a 18650 has "only" 470 lumen) and it needs only 4 AA's that can be found all over the house when in trouble. (The EA8 however can operate also with only 4 cells so in fact this is a non-argument)
The dislike of the EA4 is the (I think) very sensitive side switch and the poor lockout-mode that can surprise you with a drained flashlight when you really need it. It also cannot be ordered in neutral and there are som complaints about rattling wich I really dislike in a light!.
My questions:
a) how frequently are you guys surprised by an accidential switch-on of your EA4?
b) how "cool" is the cool-white version of the EA4 compared to the neutral of the EA8?
c) are there some more pictures and movies of the EA8 beams to make a better comparison between both of the lights?
For panic situations I have a small stock of CR123's and a Olight baton S10 and S20 that both give very long runtimes at 0,5 and 5 lumens. For seeing whats going around the house I can rely on my Olight SR-90 and my Sunwayman T60CS but the possibility to have lots of light with some simple AA's, I really like!!
My questions:
