Cycling Plus, a great UK magazine, gave the 1100 a 10/10 rating last November. (Nice of Cateye to finally bring the light to the US!!) I've personally found C+ reviews to be very fair, accurate and independent of Ad budgets.
Here's a copy of their review I snagged off the web:
Cycling Plus - Nov 2006 : Cateye TL-L.D1100 As far as rear lights go this is the daddy of all the self-contained units. With 10 bright LEDs powered from just two AA batteries, the run time in excess of 100 hours (we actually got 102 hours) in legal flashing mode is simply amazing. The supplied mountings will fit seatposts from 24mm (Cateye claim 24.5mm) up to 32.5mm, with an optional mount available to fit up to 34.5mm. There's also a clip mounting inside the box to enable you to fix the light to a bag or jacket. TWO auttons on the side of the light control the two individual strips of five LEDs, which are laid out in two rows with three pointing rearwards, and a single LED at either end pointing at 90 degrees in each row. The m.o . are Bashing, constant, sequential and fast sequenti order), making 16 ways to have your light turned on. The single best thing about this light is that it's bright, anc bright at almost all viewing angles. Add to that the fact that it's well sealed, very well made, runs for ages and has a good mounting system, and this is a clear winner. : Cycling Plus Rating 10/10
FYI, they just reviewed another Cateye improved taillight, TL-LD610, in the November 2007 edition and gave it a 10/10.
Here's their review of the 610:
Cycling Plus - Nov 2007: Cateye TL-LD610 The old Cateye LD600 was a great rear light and the LD610 is the logical evolution of the design. Powered by two AAA batteries housed inside a well sealed and well made unit, its light comes from five LEDs each with their own lens "nest". The Flex-Tight mounting as found on other Cateye lights is quick and simple to use, not to mention secure and durable. The sealed rubber switch requires you to push and hold to turn it off, meaning you cannot accidentally kill the light - single pushes simply cycle between the flashing or constant modes. With the LEDs mounted further out than the old LD600 this light is more visible from wider angles and also offers longer run times; we managed just under the claimed 30 hours of constant light with 29 hours and a few minutes, but longer than the claimed flashing time of 60 hours with just over 61 hours. . 10/10 - One of the best rear lights you can buy.
I have yet to see either of these lights in person.
FWIW, I have the old LD 1000 and though it's a bright light, the mounting bracket is a bit fiddly and the light is heavy. I use it and it can certainly be seen but I am not enamoured with it. I'm curious to see how the 1100 compares.
Unless you want to go completely over the top and buy a Dinotte, take a look at the Planet Bike Superflash. I lead a weekly night ride with my bike club and can say emphatically that the Superflash is very bright, weighs next to nothing and offers a very wide beam. Though I look forward to seeing the new Cateyes, the Superflash, IMHO, is the everyday blinkie to beat!
