CBA II charge monitoring?
I believe the CBA can basically be used as a voltage monitor, by using a 0.00Amp discharge value.
Yet since the graph show the voltage against the capacity discharges, if you use a 0.00Amps discharge it will not graph.
Maybe you can still use the data by exporting it in excel or another spreadsheet software
Hello Risky,
I tried that with my Schulze, and there seemed to be some kind of cross talk between the two units. You are supposed to be able to do this, but in my case it did not work.
I have not tried it with any other charger.
Tom
