matrixshaman
Does anyone have a charger like this? It's a Saitek I got at Sharper Image several years ago and it seemed off the scale with features at the time. I think it still is a great charger with all it's features and should do all the current 1.2 to 1.5 volt batteries ( AAA, AA, C, D ). It analyzes each cell individually, gives charging time in hours, rejects bad batteries, and can charge 4 different types of batteries at one time. It also will charge regular Alkalines - although this may only get a little more use out of them if they have been used in low current drain devices. It also shows when each individual cell is finished charging. Any one have experience with this one? I don't think it does discharge cycles and you don't have a choice of charging current - although you have a choice of picking which size cell you are charging to conceivably you could charge a AAA battery as a D cell battery and it would likely charge at a higher current (I think) although I know the bigger cells take a lot longer to charge.
