Hi,
Confusion reigns here and I have done a lot of searching. If you're feeling tolerant maybe you can supply some advice.
I was searching for an inexpensive charger and I think I found one here:
http://www.dealextreme.com/details.dx/sku.936 It got a ton of good reviews.
I will be using it to keep an Ultrafire C2 fed. But I keep reading about protected and unprotected and CR123a and RCR123a and 16340. Are 16340s the same as the CR123a battery? (and I won't even get into 18650 with and without nipples and spacers and blobs o' solder).
From what I have read a pair of CR123a batts. will give me a longer runtime than a single 18650. True?
Would someone tell me the best type of rechargeables I can buy that will give me the best throw and runtime while still being safe for use in this light? It is regulated (from everything I've read here).
Here are the battery specs:
- Takes both 2xCR123A and 1x18650 batteries
- Accepted voltage input 3.6V ~ 9V
- Note: this light's the battery compartment does not have contact spring on the positive node. So protected 18650 cells (those with recessed positive node) will not work with this light without a small spacer.
I'm sure there are also quesions which I should be asking which I am not. Sorry.
If there is a reference thread somewhere which explains this please point me towards it. Believe me, I have looked.
Thanks,
Mike
Thanks,
Mike
