Hironiemus
- Joined
- Aug 16, 2010
- Messages
- 4
Hi,
I gathered some information and questions about battery charging, it would be great if someone
could verify and answer these respectively.
Actually I am new to all this and after I read here for ages I decided to
post for the first time.
I wonder which charging method would be best for charging
lithium batteries—balanced and in series or parallel?
For the technical part here this is what I found,
how lithium batteries are to be charged:
Parallel Charging
Serial Charging
On this basis it seems to me balanced serial charging is better than charging
parallel because there is no risk in overcharging single batteries.
Am I right with this?
Are the balancer connectors basically positive or negative?
So would I need to wire negative, 4.2 V, 8.4 V, positive or vice versa?
Of course all of this applies only to a hobby charger.
Can someone tell me which charging method does the Pila IBC uses?
I think I heard it uses parallel charging.
Please point out, if i missed something out or got something wrong.
Oh and before I forget: Hello to everyone at CPF. :wave:
Parallel Charging
- On one side all the plus poles of the batteries and on the other side all the
minus poles of the batteries are connected.
Therefore you can look at the batteries as they were one large battery. - The maximum (constant) voltage is to be set as 4.2 V for Li-Ion/Li-Po and 3.7 V for LiFePO₄.
- The maximum (constant) current can be found by multiplying the number of
parallel cells by their capacity and should not excess 1 C
(For example 4×2000 mAh batteries would give an maximum charging current
of 8 A). - Different battery size/capacity can be charged at once but then the charging
current has to be calculated by multiplying the capacity value of the battery
which is the smallest in capacity by the number of batteries to be charged
(i. e. 1×600 mA 3×2000 mA would give a maximum current of 2.4 A). - When charging parallel the charger (ideally) stops at 4.2 V, but it only
detects the average value so if the batteries do not charge at the same
rate, some could be overcharged and others not fully charged. - If you start charging, the batteries should not have more than 0.5 V difference in voltage,
because one battery can charge the other one, which can come out bad …
Serial Charging
- When charging batteries in series the plus pole of one battery
is connected with the minus pole of the next battery. - You must use a balancer.
- The maximum (constant) current is set as if you would charge a single cell.
(i. e. when charging 4×2000 mAh the current must not exceed 2 A since
the whole current will flow through every cell). - One balancer cable must be connected before and after every cell.
(Number of balancer cables equals number of batteries plus one.) - The balancer ensures that the voltage in every cell won't exceed the
terminating voltage (4.2 V Li-Ion/Li-Po/ 3.7 V LiFePO₄).
This is done by checking the voltage after every cell and
delivering an compensation current—if necessary—to get the batteries to the same level.
(Voltage after first battery should not exceed 4.2 V, 8.4 V after the second, and so on). - Charging batteries with different capacities should be possible but only with
a charging rate that the balancer can deliver as compensation.
