lightseeker2009
- Joined
- Jul 29, 2009
- Messages
- 681
I hope someone can put my mind at ease with my current delemma.
I'll try to keep it short.
I did buy a 4-8cell nimh battery charger today with auto cut-off, but my batteries are getting so hot that I rather stopped the charging process as I feel the charger will not cut off automatically. I am tempted to leave it and see what happens but don't want to push my luck.
This charger costed me 5 times that what I paid for a car charger made for 7.2-8.4V battery packs for my Twin Detonator offroad RC truck. But the cheap charger shuts off perfectly. The batteries are just getting hot then it's only trickle charging. That is with a 5-cell 3300mah pack.
The batteries that are getting hot with the new, more expensive charger is 2700mah AA's. My plan is to charge them while leaving them in the battery cradle of my TK40 as I don't want to charge them 4 at a time with its original charger. The charger can charge at 1, 2 or 4 amps. I used the 1 amp setting.
Just some questions.
1. What might be the reason for the charger not shutting off?
2. What is the highest safe temp for the AA's when charging them?
3. How does the charger know what voltage is the battery pack as it does not have an input setting?
4. How does the charger know what amps is the battery pack? This battery pack should be 5400mah if I'm correct as its 2 sets of 4 batteries in parallel, standerd setup of the TK40.
Any suggestions would be appreciated as I don't want acid all over my carpet:poof:
