Charging single batteries with Maha C204F?
BatteryCharger
The crazy guy next door
I've got the Maha C204F charger that charges two batteries at once. First of all, are they in series or parallel? Is there any way I can trick the charger into thinking there's two batteries, when there is only one? Maybe a low ohm resistor?
The easiest way I've found to charge a single battery in my MAHA charger (which I do on occasion) is to put a 2nd battery in with it.
-Keith
I also own a 204f and have this doubt:
I have a device which uses 3 nimh's so I wonder what happens if I put those 3 cells with another one not discharged at the same rate or level?
will all the 3 cells end up charged equally?
Pablo
I don't own the C204F, but here's what they said about the C777+2 charging cells in series (the C777 takes 1-12 cells, but all in series, one channel only) - they will cut off the moment the first cell reaches capacity.
From what I know, the alternative would be to keep forcing a charge into the pack (or the pair of cells).. the fully charged cells would slowly cook to death from overcharge while the rest of the cells charged up to capacity.
Nope, the 204 is really a 2 cell or dual 3v charger. If you just thow another cell in there depending on it's charge state it will over charge one and undercharge the other.
If you put a dummy cell or blank cell it in there with it, the charger will try to push it to 3v
[ QUOTE ]
[/ QUOTE ]
So wouldn't a resistor with similar resistance to a NiMh battery work? Basically you'd have a battery that never gets full.
[ QUOTE ]
PEU said:
so no solution for odd (1 or 3) batteries in the 204F?
Pablo
[/ QUOTE ]
I would think that *eventually* the secondary "trickle" charge would bring all the cells up to the same state of charge. Obviously, this would take a long time though.
Peter
Hi there,
I finally got around to trying the resistor 'fooling' idea
and it didnt work at all on my charger. Instead, i found
that two diodes in series worked.
See the new thread "Two Diodes Fool Charger".
I tried 1 and 1.5 ohms, but only the two diodes worked.
Take care,
Al
