KentuckyMike
Hey everyone,
I've adopted a Raw NS as my new pocket light. Its use brings up a few questions about unproteced 14250s. I apologize if these have been asked before, but I'm having trouble searching at the moment, and surfing came up empty.
1) What should be considered the lowest voltage the battery should be allowed to go (to avoid damage)?
2) Same as above, but rather than to merely avoid damage, to also maximize cycle life,
3) Is the 4.12v I'm getting from the Nano ok? Should I pull it off at 4.11 or 4.10? Could it be allowed to trickle a touch higher without damage/danger?
4) Would daily charging (often shallow discharging) harm cycle life, or extend it?
I know the normal advice is, "as soon as you see a drop in output, pull it and juice it," but in my situation this is difficult. I use the light for various tasks in various levels of ambient light throughout the day, and on low for 3-10 minutes a night to check on animals and get to bed at night (with a burst of high at the top of the stairs to make sure the door downstairs is secured). I use it in such short bursts that I don't see an output drop, and I think the drop could be days in coming at times. (Tonight, for example, the cell reads 4.03v on the DMM, and it was charged to 4.12 fresh and 4.11 rested last night. That is from last night's ritual and a bit of use, and a touch of showing off, today.)
I want to keep a good charge, because I may need to use high heavily one day, but I also don't want to sacrifice cycle life. And it seems mistakes in charging/discharging would be magnified in such a small cell. Would working with two batteries (switching each night to extend time beween charges on each cell) help at all?
What do you think? Thanks in advance!
--Mike
--Mike
