Thanks cy,
Btw, 5C collets are available in 1/64" (.0156") diametric increment steps. They are also available in standard square and hex sizes. "Emergency collets" can be had in nylon, brass, and soft steel, and in the case of the steel ones, with head diameters up to 6". They come with pins you clamp down on while you machine the inside to the diameter or shape you want. You then remove the pins for it to clamp your parts. You can even thread them for holding threaded parts. (Can't say I'm too enthusiastic about swapping threaded parts in and out without stopping the spindle like I can for small round ones. /ubbthreads/images/graemlins/icon15.gif )
They also make 5C "expanding" collets for holding work from the inside. These don't come for standard sizes, rather you turn them down to the size you need. For production or even toolroom work on odd parts you can't hold on the outside, they are hard to beat.
Some other very handy 5C goodies are the "spindex" which allows you to rotate the collet and workpiece in defined angular increments- think accurately-located tritium vial slots, and the one built into a 90deg angle block. It allows you to mount it with the collet vertical or horizontal while clamping to a mill or grinder table. On the good ones, the collet doesn't move up and down as you open/close it. I recently bought a cheapie for work but it is a POS.
Individual collets range from ~$10 for a cheap import to ~$70? for a 6" "pot chuck." I think I've blown about $1500 on 5C stuff setting up my home shop in the last couple months. /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/grin.gif
Larry
