Illum
I've built a luxeon [yeah, old school I know
] based walkway lighting that is powered by a AC-DC power supply that feeds exactly 5V at 1 amp. Turns out iomega adapters are more regulated than any other wall wort I have came in contact with.
The adapters plugged into a switched AC outlet out in the workshop. Whenever I need to operate machinery I'd engage the power, when I leave I turn it off. I installed these suckers because the "walkway" that leads to the side door is currently a "out-of-the-rain" storage area thats pretty tricky to maneuver around. Currently its manually engaged by a switch beside the door, but sometimes I forget to turn that switch on at night and wind up having to mouth a flashlight when heading back.
I'm looking at this guy's invention: a single LED light running off a 9V battery and has a sensor to turn it off in daytime and on at night.
My LEDs are wired 5 in parallel with resistor stepdown
Vin: +5VDC, LEDs are 3.5V@<200ma each
Can I change any components to adapt to the schematic above?
