Sold/Expired closed: O-rings for SASE
Drywolf
Golden Poppy State
Will trade one set of O-rings for a SASE. The first seven to request a set will get one set. I will PM the seven traders with my address after the seven slots are filled.
I have seven sets of O-rings
Each set has at least one and maybe two of the following sizes
#015 Silicone
#016 Silicone
#017 Silicone
#019 EPDM
#025 EPDM
#1 mcmc --------------- sent
#2 Steve L (plus Buna) -- sent
#3 datiLED ------------- sent
#4 Illumination --------- sent
#5 Ducaticorse --------- sent
#6 alphazeta ----------- sent
#7 InFlux
I also have two extra “2X22mm Buna” O-rings. If you need one of these please say so and the first two CPFer’s to ask will get one with their set of O-rings.
Thanks,
Frank
The following is borrowed from McGizmo forum. Please go there for verification if needed.
O-Rings 4 a few McGizmo lights
XR27 & S27 Head:
Window Seal O-ring - 2 x 22 mm Buna (Nitrile)
Window retaining O-ring - #025 EPDM
Head to pak Seal - #017 Silicone (red)
PD Piston:
Piston to sleeve seal - #015 Silicone (use #016 for added protection but stiffer activation)
PD head:
Window Seal O-ring - #019 EPDM
Head to sleeve seal O-ring - #017 Silicone
LS20:
the window is between two #019 EPDM O-rings
the piston and head/ sleeve O-rings are silicone (#016 & #017 respectively)
Re: WTT: O-rings for SASE
Wow, thank you DryWolf. I would like one set please sir.
Hi Drywolf,
Thanks for the very generous offer. I would like one set plus one of the extra “2X22mm Buna” O-rings Please.
Happy Holidays!!!
Thanks,
Steve
Thanks a bunch, Frank - I'd be interested in a set!
That's a great gesture. I could certainly use a set if you still have one available.
Thanks!
AZ
I'd like a set please! If the 2x22 can be used in a 27LT-S I could use that too.
Thanks again! :wave:
-Rob
-Rob
Hi Rob,
This is from the McGizmo forum:
27LT & 27LT-S head:
Window Seal - #023 EPDM
2x head to Pak seal - #017 Silicone
I don't think you need the 2X22. If you want it I will send it anyway.
Thanks,
Frank
