Re: Programmable Incandescent Regulator 1 sign up-thread *accepting payments*
awr,
I actually got a PM from someone here saying that if I had any questions about the Kiu-socket and its applications, you where the one to talk to.
Can you elaborate on your solutions a little?
There are two small holes in the PCB for centering the drill. It was expensive to make a 4 mm hole from factory and it posed some problems as well so we decided to do it ourselves. The reason why we did the redesign was the lack of holes for fixating the Kiu-socket.
I don't have any pictures yet because I haven't received the components yet. They should have arrived this Friday but they didn't so they'll come on Monday... Hopefully...
The big and tall capacitors I think you are referring to are probably the old electrolytic ones you saw on my first alpha-regulator. We are now using D sized tantals so they are only 2.8 mm high and the D2PAK transistor is 4.5 mm high so we are looking at a total height of 8.9 mm if I didn't forget anything.
Drilling two holes in the socket is a very good idea. Generally, I can derivative (is that the noun?) or transform whatever mathematical function you want, but I'm terrible at finding simple solutions for simple problems. Thanks!
