petrev
cnjl3 said:Just want to let you know that i received the "goods".
I am not sure if you will be checking in to this thread during your
five weeks or longer off time.
I can see that you fixed one of my PIRs but the other one is
obviously a "new replacement" because it has no mounting holes.
I will try and drill the mounting holes my self.
So as long as i keep to the same areas as the drilled out PIR -
I should be OKAY?
I seem to remember that you told Andrew that your PIR was
five layers thick - so that is why I am asking.
Thanks again- Winny!
Hi cnjl3
There should be little pilot holes where you can drill for a KIU socket (etc.) - The one you have pre-drilled is the best guide - I drilled using a 2mm drill first then a 3mm and if necessary open up a bit with a Dremel type thing
Tools that are useful - Tool #4 (from the left) is just right for opening screw holes a tiny amount
AND
Doing any fitting of the PIR in anything and Robban's http://theintarweb.net/PIR1_drill_guide_thingy.pdf is mighty useful
I found it printed out slightly small with my setup so I put the photos into Corel Draw and resized them to 30mm to get pretty perfect alignments made easy -
Thanks Robban
ALSO
Beware the Cammed reflector - The Cam hit my Neg wire and cut it a bit ! so either use a Non-Cammed reflector or you can Dremel out a channel back to the middle a bit to accommodate the Neg wire closer to the middle. Like this . . .
Cheers Pete
