I was looking into swapping the sockets on a lamp to G8 so I could use common halogen bi-pin bulbs. I'm slightly concerned about running these bulbs without a UV cover since all my halogen lamps have a cover, but I haven't been able to find how important it is. This little segment on wikipedia sounds like common bulbs should have glass that filters UV?
https://www.satco.com/s3542.html
Thanks
But after looking a bit more I'm not sure. Satco sells some bulbs which are advertised with uv blocks, and many that don't say anything about filtering. Was hoping someone could clear this up for me, I would be sitting very close to these lights.High-temperature filaments emit some energy in the UV region. Small amounts of other elements can be mixed into the quartz, so that the doped quartz (or selective optical coating) blocks harmful UV radiation. Hard glass blocks UV and has been used extensively for the bulbs of car headlights.[24] Alternatively, the halogen lamp can be mounted inside an outer bulb, similar to an ordinary incandescent lamp, which also reduces the risks from the high bulb temperature. Undoped quartz halogen lamps are used in some scientific, medical, and dental instruments as a UV-B source.
Thanks
